Help Removing Wipers
Okay, I need to remove the whole windshield wiper arm to replace the plastic cowel piece under it. The service manual says to remove the cap, remove the nut, and pull off the wiper arm... Well I removed the cap, removed the nut, and _tried_ to remove the wiper arm but the damn thing wouldn't budge. Has anyone else pulled them off before? am i missing something?
- Eric |
#7 (permalink) | |
Rene....
#11 (permalink) |
this has got to be one of the most pos designs.... why the f-
do we need to take the damn thing off just to replace the inserts? WTF. i just got done doing mine... basically just use a small screw driver and pry that pos plastic cover off. it's much easier. and you won't scratch it or anything. go easy as you pry and push forward like the diagram. you won't crack it if you go easy. i tried pinching that thing to pull out...didn't work. then push the bracket on the bottom side, pull the blade closest to the winsheild towards the outside of the car. find the tiny "LOCK" (mine was worn out and almost impossible to see) text on the insert and pull the thing out. put it back together in reverse order. took me like 30min to do this. WTF. could've done all 3 of my other cars in 10 min or less (normal design). |
| Tips For Removing Windshield Decals? | msqr | Civic SI | 7 | 05-21-2007 06:58 PM |
| Removing Rear Deck in Sedan... | HsOffRoad | I.C.E., Electrical, Security, & Navigation | 1 | 03-15-2007 11:27 PM |
| Rain Sensing Wipers? | Special Ringpop | Driving Experience | 22 | 10-06-2006 12:41 PM |
| Removing Tailights | ballplaya4237 | Do It Yourself Articles | 16 | 09-23-2006 04:09 PM |
| Replacement windshield wipers for $3.00 each! | reelbigfish241 | Do It Yourself Articles | 7 | 08-11-2006 09:27 AM |
