Old 02-28-2006, 10:19 AM   #1 (permalink)
LED Lights on HVAC
So i was taking my EX Sedan to the dealer the other day for the 4th attempt to fix a vibration problem I described elsewhere in this forum and I noticed all of my LED lights were off on my HVAC Vent Selection Buttons. Thinking none were selected I pressed the dash vents. The airflow switched to those vents, but the lights still were not working. I tried all of them and none were working. I do not believe this is a fuse, but I added to the list of problems when i dropped it off at the service department and picked up my loaner car......FYI, my loaner was a used Toyota Corolla, now I know why I didnt buy one of those either, yuck!!
DanPorges is offline   Reply With Quote
Old 02-28-2006, 11:12 AM   #2 (permalink)
CameronJr9's Avatar
Back and Forth Forever
Mine started doing this recently. It's random though. I didn't think to add it to the forum. Glad I'm not the only one with the problem. I talked with the service department and they said it's all covered under warranty. I'm just going to wait until I need my regular maintenance and then have them pull the dash out and do whatever is needed.
Old 02-28-2006, 04:34 PM   #3 (permalink)
Mine is random now as well. I went at lunch today to try to get my car back. They had me drive it again and still had all the same problems. If you hit the buttons on the dash hard enough they will light up, but as soon as you hit another bump in the road they are off again.
Old 02-28-2006, 04:36 PM   #4 (permalink)
CameronJr9's Avatar
Well, when you discover exactly what is causing it, let me know. I may be able to solve it on my own. Thanks!
Old 03-01-2006, 01:03 PM   #5 (permalink)
The dealership is replacing the entire switch assembly under warranty. Not sure if they will give me any further details as to whats actually going wrong.
Old 03-01-2006, 06:43 PM   #6 (permalink)
STIG: a tamed race driver
Jrfish007's Avatar
gotta say it sound like a connection problem if it is on and off.
Jrfish007 is offline   Reply With Quote
It's too hot!!! 2fast4u2 Water Cooler 60 09-15-2008 05:07 AM
Alarms GhostOp Civic Coupe And Sedan 8 02-05-2006 11:23 PM
david copperfied illusion - laser webby Water Cooler 3 11-13-2005 11:34 PM
you know it's 2005 when webby Water Cooler 2 10-09-2005 05:34 PM
