Old 06-14-2007, 03:01 AM   #1 (permalink)
mrJLIEU's Avatar
JLieu
Passenger Buzzing Noise / Weird Crunch Sound at Start-Up
Hey guys, had two problems on the Si that's been bugging for me for awhile, hoping someone can help me out a little bit. '07 Si Coupe.
The first one is a strange, buzzing sound (sounds like the door) on the passenger side. Although, I've found several threads on here about weird sounds emitting from the Si sedans, it seems most are/were related to an engine mount or strut. The sound I have tend to occur during bumpy roads or often during driving and sounds like a buzzing sound (what it sounds like when someone has an audio system but no deadener to help reduce the vibrations/noise). With or without music, it still occur.
The second thing is, sometimes (happened twice so far) when I start my car up in the morning (I say after 12 hours or so of being off), and the AC is on (I believe MAX A/C is also on at the time of start up), within a thirty seconds or so, there's a loud crunching sound (sounds kind of a short, amplified gear grinding sound) that goes on for a second or two. Afterwards, the car just idles and runs normally. I tried it a few times with the A/C off, and nothing happened. Another time, I turned it on with nothing, then turned the A/C on...and it made the sound again.
Only problem with this is that I can't replicate it normally, unless the car has been parked overnight. I tried to do it after work a few times (normal eight hour shifts), and it worked normally. Thanks guys.
mrJLIEU is offline   Reply With Quote
Old 06-14-2007, 11:46 AM   #2 (permalink)
I don't know, but maybe it's the a/c clutch kicking in, or the fans turning on, and then staying on?
Tiller is offline   Reply With Quote
Old 06-14-2007, 01:00 PM   #3 (permalink)
CivicChris's Avatar
Chris
I've experienced this too. At least 4 or 5 times in the past 2 months. It sounds horrible but apparently the car is fine. I think it's just the A/C kicking on. Most cars usually do have some sort of noticeable A/C kick-in but I've never heard one as rough as the Civics...
CivicChris is offline   Reply With Quote
Old 06-14-2007, 01:33 PM   #4 (permalink)
poizun's Avatar
Dan
Maybe it's just me, but shouldn't you not keep your AC switched on while your start your car? Wouldn't that put a lot of unnecessary strain on the engine?
I've never encountered any crunching on my R18...
poizun is offline   Reply With Quote
Old 06-14-2007, 03:07 PM   #5 (permalink)
CivicChris's Avatar
Chris
Well it's happened to me when I turn on the A/C, after starting the car.
Old 06-14-2007, 07:46 PM   #6 (permalink)
The odd crunch/grind noise has happened to me on start up as well. It kinda got me nervous the first time I heard it but I realized nothing was wrong with the car.
Old 06-14-2007, 11:54 PM   #7 (permalink)
mrJLIEU's Avatar
JLieu
Yeah, nothing major is wrong with it. Tried it again today, started up normally. And yeah, most likely, with the MAX AC on at start-up may use a bit of additional strain on the engine, but c'mon it can't be THAT much. Besides, sometimes...you kind of forget it's left on. *Shrugs.* The sound is pretty rough though, nice to know I'm not the only one though.
Old 06-15-2007, 06:30 AM   #8 (permalink)
Same here with the grinding noise. It only happens when I haven't started my car for a while. But it hasn't caused any problems that I can feel while driving.
guambombboy is offline   Reply With Quote
Noise (buzzing) issue nickb I.C.E., Electrical, Security, & Navigation 12 08-26-2008 01:45 PM
popping sound from right front(passenger side) sickyute Suspension and Brakes 14 11-24-2007 06:19 AM
Weird noise or vibration... spunkin82 Mechanical Problems & Technical Chat 8 11-11-2007 04:57 PM
A popping sound from front passenger when turning wheel. SonicK20Z Mechanical Problems & Technical Chat 20 03-13-2007 10:53 AM
Help.Installed si exhaust on my ex.making weird noise louieinyo Garage 18 09-27-2006 04:10 PM
