#21 (permalink) | |
on the si the accelerator pedal position sensor sends the drivers request to the ecu. then the ecu will evaluate the request and send it to the throttle motor. the motor moves to where the ecu tells it to move. not always where the driver wants it to be. |
#22 (permalink) | |
#23 (permalink) | |
how else would the ecu get throttle position information |
#24 (permalink) |
From the dead...After contemplating this I was thinking
The K-Pro ECU isn't compatible with the new digitial dash that comes with the FG. So the gauges would need to be replaced. If you used a S2000 Gauge cluster which are like $50 bucks. Use that for the gauges then utalize a RSX wiring harness, you could essentally run K-pro, and convert to Cable. The only real issue would be wiring the gauge cluster but with a little patience it can be done. In fact I have seen it done, let me find it. I have a Throttle body off of an Older K-series so thats free. Although for it to work with our Manifold I will need the KARCEPTS TB Adapter. Wiring harness 250 Throttle cable 25 S2k Gauges 50 K-pro 1000 Throttle body FREE $1325 Convert and K-proed. What am I missing here. |
#25 (permalink) |
I hate the DBW so much on this car. I had an 04 EP3 before this car and the only thing that i like about this car is the power that the engine has.
The first person on here to do a throttle cable conversion needs to post a full how-to because I am sure that a lot of people on this forum will be trying to do that. Why are they making these cars so much of a pita to tune. And dont they realize how the dbw has so many bugs and issues with it that is probably was not a good idea to put it in at all. ![]() im just so mad about the all the driveability issues with this car. sorry for venting everyone. |
#27 (permalink) | |
#29 (permalink) |
I believe all the lag we experience could be just a programming issue. If that is the case, then we are at the mercy of Honda to decide when, we, the Civic owners are worthy of an upgrade.
Please do elaborate. PS: I had Honda do an 07 ecu upgrade on my 06 A/T ex coupe. The only difference I noticed was the jolt you get from downshifting to first (AT) has changed from 8-9 mph to 5-6 mph. |
#31 (permalink) |
i chagned all the electircal wirers that hook up the the alt to the fuse box and the white wire to the battery and notice that not only the dbw trottle resondes better but the steering responds is less sloopy. and all the ground wires were changed......believe me or not.....its your lost.... cause i love the way my r18 accerates now and handles
all wires have been changed to a 4ga wire and dont ripe on me say how would that effect the steering and throttle considering that they both are electronic based equipment |
#32 (permalink) | |
#33 (permalink) | |
#35 (permalink) | |
I was merely pointing out that your car does not have electric power steering so it does not make sense how changing some wires resulted in a belt driven power steering pump to work better to result in less sloppy steering response. Last edited by blueroadster; 12-19-2007 at 06:59 PM. |
#37 (permalink) | |
Newest Wheel Whore
| DIY part II: Cable Shifter bushings (Big Pictures inside) | atruhondagrl | Transmission | 87 | 11-29-2008 11:02 AM |
| DBW to Cable Throttle? | GreySi07 | Bolt-Ons And All-Motor | 14 | 05-10-2007 04:36 AM |
| Hondata and DBW throttle | TampaSi07 | Bolt-Ons And All-Motor | 1 | 04-30-2007 02:57 PM |
| DBW Rev Hang, Throttle Lag, Online Petition | Moisted | Mechanical Problems & Technical Chat | 4 | 10-27-2006 12:59 AM |
| DBW throttle for SI | smoke7Si | Autocross & Sanctioned Drag Racing | 6 | 03-22-2006 11:26 AM |
