Old 06-10-2007, 10:24 AM   #1 (permalink)
alexv305's Avatar
Alex Valledor
What SAE oil for an SI
Honda told me to use 5w20 or 5w30 i cant remember.. for my 07 civic si. But it gets really hot here in south florida... Maybe can i use a thicker oil like 5w40? would work just as well?
alexv305 is offline   Reply With Quote
Old 06-10-2007, 10:35 AM   #2 (permalink)
adoBoy619's Avatar
Jeff
i use 5w30 since thaqts what the owners manual says. and the lid on the oil fill reads the same thing
adoBoy619 is offline   Reply With Quote
Old 06-10-2007, 12:32 PM   #3 (permalink)
Ears bleed at 70mm
sh33t_0f_p4p3r's Avatar
Tobie
i really dont think 520 530 1030 really matters all that much
sh33t_0f_p4p3r is offline   Reply With Quote
Old 06-10-2007, 12:49 PM   #4 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
+1000 just pop da hood mang
RIP Bernie Mac
RIP Andre Young Jr. http://www.8thcivic.com/forums/water...-young-jr.html
fiji06si13 is offline   Reply With Quote
Old 06-10-2007, 12:52 PM   #5 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
Well tell that to Lexus because the new LS uses 0w-30 but they said 5w-20 will work but it greatly reduces engine life......and its not that much thicker of an oil....5w-30 is fine I run Mobil 1 I would go with what the car is made for just my $.02
RIP Bernie Mac
Old 06-10-2007, 03:49 PM   #6 (permalink)
Take a day to read this entire website. Become a believer and make the switch to 0W-30.
If not, use 5W-30. Your engine needs the added viscosity for high temps.
televascular is offline   Reply With Quote
Old 06-10-2007, 10:27 PM   #7 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
ow-30 would be fine in the winter just make sure you check it incase it starts to use it.....(burn it)
RIP Bernie Mac
Old 06-10-2007, 11:50 PM   #8 (permalink)
SiLentPower's Avatar
Joe
if you want a nice thick oil 20W-50
SiLentPower is offline   Reply With Quote
Old 06-11-2007, 12:50 PM   #9 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
why would this even be brought up?
Put that in and see what happens.....that's like putting sludge into a honda engine that is way to thick for a N/A K20 motor..... it will take longer for the oil to reach small tight spots that need lubrication in essence could seize or damage engine..... Maybe turbo or supercharged because the engine temps are alot hotter and it thins the oil out so it needs thicker oil to prevent airation.....
RIP Bernie Mac
Oil Change DIY ethlar Engine 234 10-04-2008 10:29 PM
THE OIL FAQ - synthetics, intervals, weights, brands jdrumstik Mechanical Problems & Technical Chat 97 09-17-2008 03:45 PM
Everything Oil: All you'll ever wanna know atruhondagrl Bolt-Ons And All-Motor 14 06-16-2008 12:45 PM
5W-20??? Dealer insists? BLU BY U Civic SI 66 05-04-2007 12:46 AM
Oil Life Elmacho Civic SI 28 04-25-2007 06:54 PM
