Old 06-09-2007, 03:31 AM   #1 (permalink)
Right tranny fluid
I'm planning on changing my tranny fluid tomorrow morning, just want to make sure that I have the rest stuff, can you guys tell me if it is
http://img219.imageshack.us/my.php?i...luid001tz5.jpg
leonphelpss11 is offline   Reply With Quote
Old 06-10-2007, 12:14 PM   #2 (permalink)
Cmon, can someone please tell me if that is the right one... My shift from 1st-2nd and 2nd-3rd is grindy..
Thanks all for any kind of help.. lol its a simple yes or no though
Old 06-10-2007, 12:16 PM   #3 (permalink)
I would use New honda Manual transmission fluid
inyong1988 is offline   Reply With Quote
Old 06-10-2007, 01:12 PM   #4 (permalink)
distrbd's Avatar
ken
I would not use it unless I'm positive,wait until you get more info..
I've heard Amzoil MTF is the best for solving your gear grinding problem.
distrbd is offline   Reply With Quote
Old 06-10-2007, 01:55 PM   #5 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
This is the way to go honda MTF is thin like engine oil plus some Si's are overfilled from the factory...... if you use anything thicker like gear oil it could cause shift problems in the winter and damage bearings or even worse break a shift fork like my friend did.
Originally Posted by ryker View Post
intial quality should be good when you spend 20K or more on a car. If I buy a 30.00 Polo shirt I damn well expect the buttons to stay put.
Originally Posted by fiji06si13 View Post
Well said..... now relay that message to honda......
RIP Bernie Mac
fiji06si13 is offline   Reply With Quote
Old 06-10-2007, 03:57 PM   #6 (permalink)
k20z3civic's Avatar
Greg
Use this stuff and only this stuff. You could go get the green label "new" Honda MTF at the dealer. But if I were you I'd upgrade to the Amsoil. Take that Pennzoil back.
k20z3civic is offline   Reply With Quote
Old 06-10-2007, 04:30 PM   #7 (permalink)
The problem is that I cannot find Amsoil anywhere here in like Autozone or whatnot.. This is the only thing I can really find, so I just want to make sure I have the right stuff, if not, I'll just order that Amsoil off the Inet.. Can anyone with a 8th gen SI that has changed their fluid tell me which one to get!!!
Old 06-10-2007, 04:44 PM   #8 (permalink)
You will not find Amsoil at local auto stores. It is independently distributed, so you have to buy it from an authorized dealer or the official site.
I'm going to assume you have an FG2. The Pennzoil you have will be just fine, since the synchromesh type will allow the brass synchros to "catch" gears. However, know that Amsoil (or even Honda Z-1) is a superior product. The Amsoil Synchromesh MTF is the best, mostly because it is uses 100% PAO base stock.
If you can't return it, I'd say use the Pennzoil for the sake of convenience. It won't hurt your tranny if that's what you're wondering. But if I were using it, i'd change it out for Amsoil within 20,000 miles. Good luck!
televascular is offline   Reply With Quote
Old 06-10-2007, 04:49 PM   #9 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
you can go to your loval gm dealer and purchase gm synchromesh friction modified from them. it works great.
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Old 06-10-2007, 05:45 PM   #10 (permalink)
pinchycm's Avatar
The Honda MTF isn't the way to go. I had it done last week and it still pops out. I thought that it was maybe a bit more bearable, but it popped out twice yesterday, and 2nd gear is just as hard to get into. Honda's getting a call tomorrow.
pinchycm is offline   Reply With Quote
Old 06-10-2007, 05:49 PM   #11 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
many people have said the same thing as you.^ it works for awhile but thats just because its new mtf in the tranny.
:failmyharryballs:
Old 06-10-2007, 06:41 PM   #12 (permalink)
k20z3civic's Avatar
Greg
That GM syncromesh and that pennzoil stuff is all Gear Lube. That is NOT what we put in our trannys... that stuff is like 75w-90. We want 5w-30. Amsoil has just came out with a 5w-30 tranny fluid with the modifiers for tranny's and there syncro's. Don't waist your time and money... Order the Amsoil!
Old 06-10-2007, 06:49 PM   #13 (permalink)
units42's Avatar
I used the royal purple synchrotech and i havent had one problem. Now ive had the car for 6 months and only have 2k on it but its benn almost all on the royal purple. You can also buy it at pep boys o its easy to find
units42 is offline   Reply With Quote
Old 06-10-2007, 07:01 PM   #14 (permalink)
I have a fa5, the 07 civic si sedan, but thanks for all the help, im ordering 5w-30 amsoil mtf tonight
How many quarts do I order also, thanks
Old 06-10-2007, 07:03 PM   #15 (permalink)
heres my question. when do I have to change manual transmission fluid? my car is 16 months old, and have 17.7k miles
Old 06-10-2007, 07:27 PM   #16 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
buy two quarts. you wont need it all.
:failmyharryballs:
Old 06-10-2007, 08:21 PM   #17 (permalink)
That Pennzoil fluid that is pictured earlier in the thread is NOT gear oil. It is synchromesh transaxle fluid. Read the fine print.
MTF viscosity is not measured on the same scale as engine oil. 5W-30 MTF is NOT the same viscosity as 5W-30 oil! It actually comes out to be around 75W-85. Check your facts.
Old 06-10-2007, 08:22 PM   #18 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
good stuff..^
:failmyharryballs:
Old 06-10-2007, 09:02 PM   #19 (permalink)
Then why do they have these two different kinds???
M. F. Ruckus is offline   Reply With Quote
Old 06-10-2007, 09:40 PM   #20 (permalink)
Holy shit, I'm all confused now... I have no idea what the hell to order.. Can someone that actually has changed their own MTF oil tell me what to get!!!!!
Tranny fluid question Tacomac Civic Coupe And Sedan 9 06-11-2007 03:42 PM
I think my tranny fluid overfilled leonphelpss11 Mechanical Problems & Technical Chat 8 05-24-2007 02:04 PM
GM Syncromesh Tranny Fluid Tennisjon2002 Civic SI 49 03-21-2007 10:19 PM
Switched to Redline MTL (syn. tranny fluid) Leonardo629 Civic Coupe And Sedan 8 05-24-2006 07:25 PM
Changing to Synthetic Tranny Fluid 06workhorse Do It Yourself Articles 7 05-14-2006 12:41 PM
