Old 06-09-2007, 02:18 AM   #1 (permalink)
06silvercivic's Avatar
Exclamation Wtf Please Help Me!!!!!!
So i turned my car on and when i tried to move the shifter from park to drive it wouldent let me like i wasent steping on the brake or sumthing so i pressed that little realase button so i could drive my brakes worked fine but my brake lights are out all of them are out but they do light up when i have them turned o, its like they dont relize im hitting the brake, than i found out that my horn dosent work either. idk whats going on could be i blew a fuse? Please help me!!!
06silvercivic is offline   Reply With Quote
Old 06-09-2007, 03:51 AM   #2 (permalink)
Take it to the dealer. Should be covered under warranty.
taffysi is offline   Reply With Quote
Old 06-09-2007, 12:42 PM   #3 (permalink)
i cant i have a CAI installed anyone else have any suggestions
Old 06-09-2007, 12:45 PM   #4 (permalink)
CUPRA's Avatar
Nunya...
Could be something as simple as the brake relay switch, that lets the transmission know the brake pedal is engaged before allowing you to select a gear.
Something the dealership should look at tho...
CUPRA is offline   Reply With Quote
Old 06-09-2007, 12:49 PM   #5 (permalink)
elementofhoops's Avatar
Take the CAI off? I dont know a lot about them but can you take it off and take it to the dealer?
elementofhoops is offline   Reply With Quote
Old 06-09-2007, 12:59 PM   #6 (permalink)
midnightex's Avatar
Tobey
The CAI shouldn't effect this at all. The only time you have a problem with mods and warranties is when the aftermarket part is the direct cause of the failure for any part it's connected to.
i.e. CAI caused failure of TB
I can't see how a CAI could affect whether or not your brake lights work or whether your car shifts out of P.
My best friend had an AEM V2 intake on his Accord and the dealership never said anything to him when he took the car in for problems. The dealership even took it off that Accord when he traded it in on a new Accord, and then installed it for him on the new one.
Take it to the dealership.
midnightex is offline   Reply With Quote
Old 06-09-2007, 01:50 PM   #7 (permalink)
radiocontrolhead's Avatar
Danny
Perhaps during instalation he cut a wire or grounded a wire improperly. It could lead to this cacuse. Remove the CAI and take it to a dealership. If you have doubts about this method, call a bunch of local dealerships and ask them if they will still work on your car under the warranty if you have a CAI installed. It doesn't hurt to ask, and don't give them your name; it's a general question.
Old 06-09-2007, 03:32 PM   #8 (permalink)
Was it running after the CAI install?
And don't let the dealership give you crap over the CAI. Have them tow it in for you.
bluesunit is offline   Reply With Quote
Old 06-09-2007, 09:40 PM   #9 (permalink)
Buy a shop manual...read...gain knowledge...problem solved.
blueroadster is offline   Reply With Quote
Old 06-09-2007, 09:53 PM   #10 (permalink)
Forkingkrazy's Avatar
Berice
The horn and brakelights might be on the same fuse. check your fuse box and see if any of them are blown or burnt. Must be a new safety precaution on the new cars. i had a problem like that with my old 89 Accord DX. When i blow the horn.. the brake lights would stop working because they weer on the same fuse. Electrical fault somewheer was to blame.
Forkingkrazy is offline   Reply With Quote
Old 06-09-2007, 11:49 PM   #11 (permalink)
sgtpruitt's Avatar
Tim
A CAI does not void your warranty. Take it to the dealer.
I thought the point of this forum is to gain knowledge.
sgtpruitt is offline   Reply With Quote
Old 06-10-2007, 12:01 AM   #12 (permalink)
Kneel before Zod!
atruhondagrl's Avatar
General Zod
Courtesy of sitting for months without being started, my car had issues last week when I got in it. The horn didn't work and about 5 other things including my cruisecontrol. Check your main fuse box under the hood. Look in your manual for the proper fuse that controls your horn, check it. It may be blown. Thats what I did. I changed the fuse and now the car is fine.
Rise before zod.
AWD is RWD with training wheels.
atruhondagrl is offline   Reply With Quote
Old 06-10-2007, 10:35 PM   #13 (permalink)
HondaFREAK's Avatar
fuses blow without having the car running? that's odd
HondaFREAK is offline   Reply With Quote
Old 06-10-2007, 11:41 PM   #14 (permalink)
SiLentPower's Avatar
Joe
It is definitly a fuse or a relay. More likely a fuse. Check your horn, and brake light fuses, and your brake relay; I am pretty sure that automatics have one in the fuse box.
SiLentPower is offline   Reply With Quote
Old 06-10-2007, 11:44 PM   #15 (permalink)
BATANG CITY JAIL's Avatar
dealership FTW!
Old 06-13-2007, 05:08 PM   #16 (permalink)
Duce2k's Avatar
Sounds like a fuse issue, don't panic, just check all your fuses, it's easy enough
Old 06-13-2007, 05:11 PM   #17 (permalink)
Originally Posted by BATANG CITY JAIL
dealership FTW!
Funny guy.
Old 06-13-2007, 08:17 PM   #18 (permalink)
whoops misread... and u've probably taken it to the dealership anyway.. lol
taejinah is offline   Reply With Quote
wtf will they think of next?!?! Si_on_my_back Water Cooler 0 05-09-2007 04:12 AM
Wtf! Si's get no respect from other drivers! Bballswingr1 Autocross & Sanctioned Drag Racing 76 04-10-2007 05:49 AM
WTF am i getting old?? Streethonda06 Water Cooler 49 01-29-2007 07:44 PM
Washing the car and bugs WTF?!?! 06CivEXJon Detailing 15 10-25-2006 11:28 PM
