Old 06-08-2007, 02:11 AM   #1 (permalink)
Injen CAI help
I want to install my Injen CAI, but I don't want to cut the fender to install it, I'm planning on just putting like something in between it so it doesn't rub. Will this work out?
Does Injen make Hydro shields for the Injen CAI? So in case I do end up having to cut it, I want to have like something that will block the water just in case my wheel sprays water into there. I have madddd rain down here in Louisiana so thanks for any help
Sorry if this has already been answered, but I don't honestly have time to search at the moment so please don't flame me or close this
leonphelpss11 is offline   Reply With Quote
Old 06-08-2007, 02:13 AM   #2 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
Yes you can get away without cutting, I have CAI and Fogs, and yes they make hydro shields... i have one for mine
|108K Miles|I beat my tires harder than i beat my meat
ryryninja is online now   Reply With Quote
Old 06-08-2007, 02:14 AM   #3 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
You will see a buldge in your fender liner if you don't cut it. I didn't cut mine and it was fine for the 20,000 kilometers. I don't think putting something in between the two is a good idea. There's already very little space.
Yes, they have hydroshields. I think you can find it on http://www.corsportusa.com/
Old 06-08-2007, 04:10 AM   #4 (permalink)
I meant putting like some foam or something in between there, something durable yet soft so it's not plastic on plastic and maybe that rubbing will eventually lead to the piping having a hole in it
Old 06-08-2007, 11:46 AM   #5 (permalink)
blackpearl06's Avatar
Nolan
I installed mine about a week ago without having to cut. Basically just popped the two tabs off the fender wall behind the wheel (turned the wheel all the way left) and slid the intake in that way. It took a little bit of effort to snap the pins back in, but it eventually did. There's really not much of a bulge at all. And I really dont think that the aluminum will wear a hole if its rubbing up against plastic. some sort of padding in between wouldn't hurt, though.
blackpearl06 is offline   Reply With Quote
Old 06-08-2007, 12:06 PM   #6 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
There shouldn't be any wear between the pipe and the wheel well.
Old 06-08-2007, 12:08 PM   #7 (permalink)
sgtpruitt's Avatar
Tim
Same here. You don't have to cut and I ran my car through an auto wash with undercarriage spray and it did not get the filter wet. I think you'll be alright. Taking the tabs off takes literally seconds vs cutting.
sgtpruitt is offline   Reply With Quote
Old 06-08-2007, 12:09 PM   #8 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
I didn't even take out the tabs when I installed it, I just shoved it in there.
Old 06-08-2007, 12:10 PM   #9 (permalink)
sgtpruitt's Avatar
Tim
I can see that.
Old 06-08-2007, 12:12 PM   #10 (permalink)
sgtpruitt's Avatar
Tim
$30
Old 06-08-2007, 03:11 PM   #11 (permalink)
mikepesikan's Avatar
I didnt cut mine, I did put a hose clamp on the intake right where it rubs on the sheet metal, so it rubbed on the clamp instead.
mikepesikan is offline   Reply With Quote
Old 06-08-2007, 09:08 PM   #12 (permalink)
Interesting, I might try that..
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 92 11-11-2008 08:57 PM
Injen CAI vs AEM CAI Review....hesitation etc. sickyute Bolt-Ons And All-Motor 118 10-07-2007 09:40 AM
Question about Injen CAI install on Si with fog lights Vi3t DrAgOn 714 Bolt-Ons And All-Motor 2 04-19-2007 12:22 PM
Which one first: Injen CAI or oem fogs?? reaper702 Bolt-Ons And All-Motor 22 09-02-2006 04:15 PM
Just Installed Hondata (new rev 8/1) flashed Ecu and injen CAI my06si Bolt-Ons And All-Motor 8 08-05-2006 01:51 AM
