Hi all,
I just recently bought an 07 honda civic si coupe. I am having trouble shifting from 1st to 2nd gear. Every time I do so, the car either jerks forward or backward. Can anyone offer me some useful advice as to how I can properly shift between these two gears? |
#3 (permalink) | |
honest to god ive had my si for over a year now, been driving sticks on many vehicles and for a long time, i have the same prob with my si. what i have noticed is that if you drive normal it doesnt like the 1 to 2nd change but if you bring it up to like 4 grand it shifts alot smoother.
All you need to do is make sure to rev match on your up shift. What is happening is that the engine is either rotating too quickly or too slowly to match the speed of the vehicle in the selected gear. Trust me this drove me nuts on my EX for six months, but I learned to compensate for it.
To better explain what is going on, let me explain a different scenario where a lot of people (including myself) want to blame the gearbox instead of ourselves. Many times while down shifting, especially into second gear, it feels as though the transmission "sticks". In reality, what are feeling are the synchronizers in the gearbox attempting to match the speed of the gear to the speed of the engine. The synchronizer for second gear usually gets such a workout that Honda actually uses a double cone synchro for second gear in most, if not all, of their designs. I'm not going to go too in depth about the finer points of rev match shifting, but on the upshift the technique is simpler than you might think. All you need to do is have a very "light touch". When you shift into the next gear, depress the clutch, take the car out of gear, but before putting it back into gear pause in neutral for just a moment. Put only a slight pressure on the shifter pushing it into the next gear. The resistance you feel is the synchronizers. As your engine's rpms drop to the perfect level so that it is spinning in unison with your gears, you will suddenly feel the shifter being "sucked" into gear as the resistance from the synchronizers goes away. Once I mastered this light handed technique, my shifting has become smooth as silk, almost like I was driving an automatic. I'm getting pretty good at rev-match down shifting as well but I need more practice with getting just the right amount of throttle. Eventually I hope to master the heel-toe downshift, but my coordination isn't there yet. |
#11 (permalink) |
I'm going to give your method a shot today. Hopefully it works. I don't seem to have any problems shifting from 2-3 or 3-4 or 4-5 or 5-6. It's just with 1-2. It's so frustrating and I keep cringing when this happens thinking i'm screwing up my new car. Ahhh, the agony. :)
#14 (permalink) | |
#15 (permalink) | |
#19 (permalink) | |
I have a question about this technique. This is how I performed this: First I depressed the clutch, then put the gear in neutral and lightly pushed the shifter towards second but not fully into second. Then I slowly released the clutch but not fully. When i felt that the shifter was not going to get "sucked" in, I quickly depressed the clutch and put into second gear. During this entire process, I did not touch the accelerator. I'm having trouble with the technique and still cringe everytime the car jerks forward or backward during my shifting. I think I got worse at my shifting because now I'm have some trouble shifting perfectly to 3rd. :) I have no idea what to do. I just keep worrying that I'm messing up the car. Can anyone help??? |
#20 (permalink) | |
So I should be shifting at about 4k or slightly more? Does this work for everyone else also? Also, is it about the same between the Si and the DX/LX/EX. I have an Si so I'm wondering if your suggestions would apply to me. I guess I'll try it at 4k today. Man that seems like a really high rpm. Engine noise must be very noticeable at that point? Also isn't that a waste of gas??? |
| Memorial Day Thread | webby | Water Cooler | 31 | 05-28-2007 10:38 PM |
| 1st to 2nd gear grinding at high rpms | pate2901 | Mechanical Problems & Technical Chat | 2 | 04-22-2007 03:19 PM |
| 07 Problems | todsulli | Mechanical Problems & Technical Chat | 33 | 01-29-2007 11:38 AM |
| 1st and 2nd gear hopping (It feels like it's starving for Air or Gas?) | shadowone | Mechanical Problems & Technical Chat | 21 | 08-18-2006 11:37 AM |
