Old 06-05-2007, 04:16 PM   #1 (permalink)
RSPjean's Avatar
Jean
clutch is gone ( pics on page 7)
ok i was about to hit 10,000 miles and my clutch went out like gone as in no first gear no moving the car nothing is this covered in any warrenty or am i stuck with a huge bill and how huge of a bill
RSPjean is offline   Reply With Quote
Old 06-05-2007, 04:19 PM   #2 (permalink)
Tuna Fiddle™
twistedframe's Avatar
Dave
I doubt it will be covered since a clutch is considered a wear item. unless you can prove that something on the car forced the clutch to wear out early your gonna be stuck paying for it.
Old 06-05-2007, 04:21 PM   #3 (permalink)
jtreank20's Avatar
jerad
it should be covered in warranty. there is no way that it is normall for ur clutch to wear out in 10,000 miles. no way. take it to the dealer!!
jtreank20 is offline   Reply With Quote
Old 06-05-2007, 04:23 PM   #4 (permalink)
Tuna Fiddle™
Dave
no way except driver error. I work at a nissan dealer and see cars with less miles than that come in with blown clutches and customers pay for them all day long. Unless they pull the trans out and find something in there causing the problem it shouldn't be covered.
Old 06-05-2007, 04:25 PM   #5 (permalink)
LoverOfCivics's Avatar
Javier
how much is a stock clutch?
LoverOfCivics is offline   Reply With Quote
Old 06-05-2007, 04:26 PM   #6 (permalink)
RSPjean's Avatar
Jean
this is going to cost me my vacation to mexico
Old 06-05-2007, 04:31 PM   #7 (permalink)
adoBoy619's Avatar
Rollin
same thing happened to me at almost 10,000 miles. the guy told me the same. it is a worn item so they dont usually cover it. but he talked to his people and got it done for free since hes pretty cool guy. most likely its driver error. but i learned my lesson now
adoBoy619 is offline   Reply With Quote
Old 06-05-2007, 04:38 PM   #8 (permalink)
reaper702's Avatar
i don't know but this seems to be going on a lot with the new si. i seen a lot of ppl with clutches gone out at the 10k mark which seems odd to me. even mine went out at 10k and i know it wasn't my error for the most part. in my case, the clutch wasn't completely out, it had a few more thousand miles, but it was slipping when you got on it in the upper rpms. the stealership said that they found nothing wrong with it when they drove the car, but did mention that in case it was the clutch, it would be out of pocket.
reaper702 is offline   Reply With Quote
Old 06-05-2007, 04:39 PM   #9 (permalink)
I'm a service advisor at Acura... i have never seen a car tl, rsx, tsx neither come in with 10k or less and have the customer pay the bill. We may give the customer crap at first...but most customers will put up a fight and then we just fall and say yeah we'll cover it. Clutches are usually 12months 12k anyways so
justinj14 is offline   Reply With Quote
Old 06-05-2007, 04:39 PM   #10 (permalink)
Javier
Old 06-05-2007, 04:40 PM   #11 (permalink)
reaper702's Avatar
son of a bitch! i knew i should have fought it, but i wanted an aftermarket clutch. 10k is insane for a clutch to go out.
Old 06-05-2007, 05:27 PM   #12 (permalink)
RSPjean's Avatar
Jean
do you guys think i should go with a stock cluth or since i have to change it might as well go aftermarket? any suggestions ?
Old 06-05-2007, 05:58 PM   #13 (permalink)
NitrousG35's Avatar
Wild VTEC'n Bill
10,000 miles is premature wear unless they could make a case that you were tracking your car. I would see if the dealership is willing to be merciful to you and fix it. Never hurts to ask.
Old 06-05-2007, 06:48 PM   #14 (permalink)
adoBoy619's Avatar
Rollin
next time, hopefully not anytime soon, i plan on going aftermarket
Old 06-05-2007, 06:51 PM   #15 (permalink)
SIcBoy's Avatar
jr
f*** stock while your down there you better upgrade
SIcBoy is offline   Reply With Quote
Old 06-05-2007, 07:02 PM   #16 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
I would tend to agree. If the clutch issue you have 'was' generated from your driving habits a replacement stock clutch isn't going to last very long (barring adjustement of driving habits). I would give serious consideration to an aftermarket clutch.
That is certainly what mine will be replaced with when it eventually goes.
Janizary is offline   Reply With Quote
Old 06-05-2007, 07:07 PM   #17 (permalink)
seans-fbp-si's Avatar
Sean
my clutch went at 19000 miles and it was not covered under warranty, i fought with honda about it alot. silko honda charged me $1200 to repolace it.
really sucked bigtime
seans-fbp-si is offline   Reply With Quote
Old 06-05-2007, 07:10 PM   #18 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
All of you who might be having clutch problems... do your best to try and find someone who knows how to install the clutch.
I know Honda was trying to screw me over saying I needed a new clutch, shifter and transmission... .when I finally pulled out my old clutch..... it was missing pieces and even one of the springs were destroyed.
I was upset at what they had said at honda and never even bothered to ask to look at the clutch itself because they said they tore apart my tranny.. but I doubt that seeing how they did it so fast in maybe 50 mins...
Good luck though....
|108K Miles|I beat my tires harder than i beat my meat
ryryninja is online now   Reply With Quote
Old 06-05-2007, 07:11 PM   #19 (permalink)
BLU BY U's Avatar
if you paid $1200 to repalce a clutch, you got f*cking owned hard core. A clutch kit costs $350 max. labor is about 3 hours (70-90 bucks an hour). the techs probably wen tout to the titty bar with your money. Its not even hard to change the cluthc on a fwd vehicle. You can do it yourfself in a day.
Ive got 20k on my stock clutch and still grabs like a son of a bitch. I dont drive easy either. Stop riding your clutch
Old 06-05-2007, 07:12 PM   #20 (permalink)
RAWRRR
jpik2003's Avatar
Jack
I'm going to take a wild guess and say this is your first stick car? You're probably riding the clutch like crazy. If this isn't the case, my mistake.
jpik2003 is offline   Reply With Quote
Newbie guide for Manual Transmissions Tastycakes Mechanical Problems & Technical Chat 131 07-02-2008 02:05 AM
Exedy Hyper Single Stage III Clutch Kit: Part Details (PIC Heavy) blueroadster Forced Induction And Nitrous 103 12-18-2007 11:23 AM
clutch issue jdmk20z3 Mechanical Problems & Technical Chat 4 03-06-2007 10:24 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 08:34 AM
