Old 06-05-2007, 12:08 PM   #1 (permalink)
Si Sedan Oil question
hi all
Something strange happens to my car, i went on a trip to China for one month and i left my car at home, before I left I check the oil level and everything was ok, now that im back i check the oil level again and it was very low. Is it normal that the oil level went down for not using the car?
There is no oil leak btw.
dennisc is offline   Reply With Quote
Old 06-05-2007, 02:08 PM   #2 (permalink)
Did the oil get below the lowest mark on the dipstick? If not, check oil when engine is warm and see what happens. If it's still low, and you don't see any leaks, just add more and watch it carefully from now on.
dextor is offline   Reply With Quote
Old 06-05-2007, 02:33 PM   #3 (permalink)
radiocontrolhead's Avatar
Danny
All your oil has slowly dripped to the oil pan and was compressed. You are supposed to check your oil when the engine is at operating temperature but with the engine off. Run the car at operating temperature, shut it off, and check the oil. You should get the same level. If not, check under your car to see if there is oil leaking.
Old 06-05-2007, 02:42 PM   #4 (permalink)
This morning I start the car and let it warm up, then I stop the car and check the oil, i wasnt below the mark but it was very low, lower than the last time I check it before my trip, i just added some oil again but theres no oil leak, i check that already.
Old 06-05-2007, 06:01 PM   #5 (permalink)
NitrousG35's Avatar
Wild VTEC'n Bill
Maybe you have oil parasites!
Old 06-05-2007, 06:11 PM   #6 (permalink)
Danny
It will be close enough to the mark you last saw, but probably won't be exactly the same. When did you check the oil last time? Was the engine running for longer times? It depends. The longer you run the car, the more the oil will get distributed everywhere internally. Run the car and next time you fill up gasoline, check the oil and top off accordingly.
Oil Life Elmacho Civic SI 32 12-02-2008 03:01 PM
Oil Change DIY ethlar Engine 251 12-01-2008 10:46 PM
Bass in a LX sedan question.... Bicudo2 I.C.E., Electrical, Security, & Navigation 17 05-25-2008 08:33 PM
Question for Sedan Si owners with HFP Aero Kit whiterice Inside and Out 8 01-23-2007 10:33 PM
TOV: Si Sedan first drive skittleslegend Civic SI 38 09-24-2006 12:46 AM
