Old 06-04-2007, 08:14 PM   #1 (permalink)
FusionSi11's Avatar
Reese
engine coolant question...
i just took off my bumper (with the help of Kurt) to get my headlights off to ship to get my retrofits done . I noticed that my coolant was low...i currently have 32k miles on my baby and i was thinking whether its time to change my coolant for my car. Since my coolant was low, i topped it off with Prestone 50/50 coolant. Do you guys think its time to change my coolant? Since im thinking of changing it, should i replace it with OEM Honda coolant Type2 or Prestone 50/50 Extended Life Coolant?
FusionSi11 is offline   Reply With Quote
Old 06-04-2007, 10:54 PM   #2 (permalink)
kenchan's Avatar
my coolant was low only 5-6 months after i got the car. i just added the
Honda genuine 50/50 mix. since then, the level have not dropped.
Old 06-05-2007, 01:56 AM   #3 (permalink)
I wouldn't worry too much about changing it. This import specialist mechanic (see links below) recommends 30k coolant changes, but I think its a little overkill. But since it's pretty inexpensive so I suppose why not? I would go with honda coolant even though im pretty sure you would never notice the difference with prestone.
http://www.artsautomotive.com/coolingstory.htm
http://www.artsautomotive.com/GenuineFluids.htm
TeaSX is offline   Reply With Quote
Old 06-05-2007, 02:15 AM   #4 (permalink)
Honda recommends changing the coolant every 100,000 miles. I think that's too generous... 60-80k seems safer. But they spec such a huge interval because of Honda's Type-2 Long-Life coolant. Adding Prestone 50/50 may have diluted it a bit.
My opinion is that you can wait until 60,000 miles to change it with no harm done. Just make sure you use Honda's Type-2 from now on.
televascular is offline   Reply With Quote
Old 06-05-2007, 07:55 AM   #5 (permalink)
Honda Canada states on any 01 and newer of it's vehicle the coolant is good for 192,000km's or 120 Months, whichever comes first and then to relpace it every 96,000km after that or every 60 months.
So, I would suggest leaving it how it is for now, or replacing it with the genuine Honda fluid and then leaving it.
Cheers
Tiller is offline   Reply With Quote
Old 06-05-2007, 07:55 AM   #6 (permalink)
...double post....sorry
Old 06-05-2007, 04:35 PM   #7 (permalink)
udumkid's Avatar
Rene....
You do know you have to check the coolant level when the engine is cold,right?
udumkid is offline   Reply With Quote
Old 06-05-2007, 09:14 PM   #8 (permalink)
Metalhead852's Avatar
Michael
Same here right at 6 months it droped to almost the minimum mark.
Metalhead852 is offline   Reply With Quote
Engine coolant/ Motor Oil RomesKdUB Forced Induction And Nitrous 39 04-26-2007 03:32 PM
DownShifting!?! roadrunner1659 Driving Experience 88 02-08-2007 02:56 PM
New Engine for 08 Corvette KingMarineM16a4 Garage 1 01-17-2007 11:26 AM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
'06 Hybrid Pricing shoptb Civic Hybrid 23 09-30-2005 12:59 AM
