Webby's Minion
They shouldn't be able to pull it off of your VIN. They would need to grab the serial number off the back of the radio, which means labor cost to pull it out of the center console.
You should have received the code on a card (about the size of a business card) with the packet that contained your manual and quick guide. Some dealers hide the card within the manual or simply place it inside your glove box. If your dealer was nice enough to help you set up an Owner's Link account on Honda's website, they may have been nice enough to enter in the radio code there as well. |
well thats the main reason i wanted the code is to update my owner's link account. I can not find this card with the radio code ill check all my stuff again but havent had any luck, ill try looking on the inside also to see if i can locate it. if i have to ill take out the radio and get the serial code to avoid paying labor charges....
The original --> "J" <--
Yea unfortunatly if the sticker was never put in the box and u dont have the card, ur going to have to pull the radio our. it sucks. good luck though
#10 (permalink) | |
#11 (permalink) |
Holy Crap!!!™
You should be able to retrieve the serial number from your radio without pulling it out.
make sure car and radio are off... hold the 1 and 6 button turn ignition to accessory while holding 1 and 6 turn your radio on still holding 1 and 6 the radio will show 4 numbers and then 4 more numbers this is your radios serial number. Call your dealer with this 8 digit number and they will be able to get the code for you. |
#14 (permalink) |
this just happened to me yesterday, I had to disconnect the battery in order to intall my SRI, i called a buddy of mine who works for honda and he told me to open my glovebox, i found a small sticker with the numbers i entered them and bam! radio works, He told me it would have cost me 30 bucks for them to just look at it! they need to pull the radio match the serial numbers then call honda for a verification ect ect.
#16 (permalink) |
I can confirm they do not need to pull the stereo on new honda vehicles....any civic 2001 and newer you can get the serial number from the radio using the old 1 and 6 trick. This also works on any 2003 and newer Accords, and any newer model.
As some other people have said, if you get your serial number and call it in to a dealer they will not give you the radio code without confirming ownership of the vehicle. So you might as well just stop into the dealer with your ownership to speed things up. PS: The dealer does not have to call Honda to confirm the serial number, they quickly run it through our Honda online system and it returns the proper radio code. Cheers. |
#17 (permalink) | |
#18 (permalink) | |
thanks for that info!!! ill try this with the dealership as well! |
#19 (permalink) |
just wanted to say thanks to everyone on this! turns out to get the serial # the radio needs to NOT be working LOL!!! whoops!!!
Rene - thanks for calling me back and plus rep for you when i see your next post!!!! while on the phone with Rene i found the radio code!!! it was written down on the inside of my delivery check status!!!
#20 (permalink) | |
Rene....
| DIY: Aftermarket radio Install in an EX | xtv-sidecar | Audio | 247 | 11-10-2008 09:08 AM |
| Where is the radio code??? | Johannes | I.C.E., Electrical, Security, & Navigation | 18 | 01-25-2007 02:11 PM |
| Factory Radio Code - SI non Nav | Shark Tek | I.C.E., Electrical, Security, & Navigation | 15 | 08-07-2006 02:29 PM |
| Heads-up...ALERT!!!! Protect your radio code | MyFirstCivic@35 | I.C.E., Electrical, Security, & Navigation | 6 | 04-16-2006 01:48 AM |
