Old 05-31-2007, 02:41 PM   #1 (permalink)
Bubble Gum Jr.'s Avatar
Dave
Noise from braking and sharp turns?
Sometimes when I brake or do a sharp turn, I hear a clunking sound and I know it's coming from the wheel well. What the hell is it?
Bubble Gum Jr. is offline   Reply With Quote
Old 05-31-2007, 03:21 PM   #2 (permalink)
pure2.0's Avatar
Check out some of the recent "clunk" threads.....no one knows exactly, besides saying it is probably just the suspension.....
pure2.0 is offline   Reply With Quote
Old 05-31-2007, 03:29 PM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
the abs in our cars is VERY sensative....that was probobly what you heard
NIGHTHAWKSI is online now   Reply With Quote
Old 05-31-2007, 05:20 PM   #4 (permalink)
Dave
Could it be the CV Joint?
Stolen from Wikipedia:
Constant velocity joints are usually reliable and largely trouble-free. The two main failures are wear and partial seizure.
Wear in the outer joint usually shows up as vibration at certain speeds, a bit like the vibration caused by an unbalanced wheel. To determine if the joint is worn, find a big empty car park and drive the car slowly in tight circles, left and right. Worn joints will make a rhythmic clicking or cracking noise. Wear in the inner joints shows up as a "clunk" or "pop" when applying power, or if severe, when lifting off the throttle.
