Old 05-30-2007, 11:28 PM   #1 (permalink)
Short Stops & Almost Stalling
Hey,
Just curious if anyone else has ever had this problem.
I have a 06 LX sedan with 12K on it now. Auto tranny.
Every so often if I have to stop very suddenly, the car just about almost stalls out then rebounds back to normal idle?
It has happened about 10 times over the 12K but when it happens, it's very noticeable.
Anyone else ever have this??
Old 05-30-2007, 11:30 PM   #2 (permalink)
Take it in to get it checked. Maybe there's a problem with the throttle or ecu, or who knows ???
dextor is offline   Reply With Quote
Old 05-30-2007, 11:48 PM   #3 (permalink)
TJ213's Avatar
its worth getting checked out, you don't want your power to fail when using the brakes
Old 05-31-2007, 01:56 AM   #4 (permalink)
It has happened to me also, the rpm's seem to drop really low as i'm coming to a complete stop, then just rev back up and go back to idle.
Old 05-31-2007, 09:50 AM   #5 (permalink)
Exactly what I have but you described it quicker and easier, heheh.
Old 06-06-2007, 03:41 PM   #6 (permalink)
90and90's Avatar
Todd
I brought mine to my mechanic, he said my engine was running really lean, I have an CAI and Exhaust, does anyone think it has to do with the backpressure, I have a MT so if I throw it in neutral and the Air Conditioning is on it almost always die's, im going post this somewhere else, also my check engine light is on and I cant pass inspection with a check engine light on... my mechanic plugged it onto an obd and thats where he got it was running lean... anyway thanks!
90and90 is offline   Reply With Quote
Old 06-06-2007, 11:33 PM   #7 (permalink)
SiLentPower's Avatar
Joe
I had this problem as well, it turned out that the filter had wiggled loose on my SRI. Tighten her down and you should be golden. I would recommend resetting the ECU as well.
SiLentPower is offline   Reply With Quote
Old 06-06-2007, 11:51 PM   #8 (permalink)
90and90's Avatar
Todd
I reset the ecu a few time's and the filter is REALLY tight.
Old 06-07-2007, 01:47 AM   #9 (permalink)
so what happened after you reset the ECU?
Should i check my filter (air filter??) to see if it's too tight?
Old 06-07-2007, 07:24 PM   #10 (permalink)
I forgot I even made this post, hehehe.
Can I just unhook the battery for a few minutes and re-hook up?
Do I have to do an ECU learn??
Thanks.
Big Holiday Sale From TWM Short Shifters! TWM Performance TWM Performance Short Shifters 40 01-30-2007 06:24 PM
short shifter madness edciv Inside and Out 5 10-14-2006 09:29 PM
TWM Short Shifter + Bushing Installed Shiznet Bolt-Ons And All-Motor 2 10-05-2006 12:27 PM
