Old 05-28-2007, 11:06 PM   #1 (permalink)
Clutch Gone Bad
ryryninja stopped over today and I changed his clutch and pressure plate. He said that the clutch was worn and would not shift into reverse when the engine was running. The car had about 50k miles on the clock which seemed a little odd that the clutch would have been spent so soon considering the type of driving (mostly highway). In any event, he is now back on the road and is a happy camper. FWIW, during the install the clutch had plenty of material left, but the fell apart (I'll let him explain the circumstances). Now for the PICs:
Clutch side one showing PICs of parts from this side. The spring broke and lodged one end into the other:
Center shaft out of wack on the same side:
Same side:
Same side:
Clutch side two showing PICs of parts from this side. Spring is the same one in the first PIC, just flipped over. At the 11 o'clock position, there is a portion of metal that sheered off and lodged under the clutch disk.
Same side where you can see all of the other cracks:
Same side:
Same side:
blueroadster is offline   Reply With Quote
Old 05-28-2007, 11:17 PM   #2 (permalink)
Skylinegtr06's Avatar
edwyn(male)
damn, powershifting it seems
Old 05-28-2007, 11:20 PM   #3 (permalink)
Yeah, clutch dumping going on there. If you didn't do it someone did before you bought that car.
Or defective.
bioevolve is offline   Reply With Quote
Old 05-28-2007, 11:56 PM   #4 (permalink)
He is the original owner...I'll let him explain the circumstances. Pilot bearing was fine and there was no excessive wear fon the pressure plate splines where the throwout bearing makes contact.
Old 05-29-2007, 12:01 AM   #5 (permalink)
faptasic... pew pew pew
rippars's Avatar
Ryan
didnt know it was that bad... aewsome that it was only his clutch and not his tranny!
< click and donate nao
Originally Posted by jasonandre
Who wants to wash my car?
Originally Posted by dentrecords
sure. where would i find it?
Old 05-29-2007, 12:04 AM   #6 (permalink)
Meaning any test drivers before him, if there was.
Old 05-29-2007, 12:12 AM   #7 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
That looks rough. Did he replace it with a stock OEM clutch or did he go with an aftermarket one?
Old 05-29-2007, 12:14 AM   #8 (permalink)
rippars's Avatar
Ryan
i believe he did go aftermarket. not sure of the brand tho.
Old 05-29-2007, 12:16 AM   #9 (permalink)
Acorns!
webby's Avatar
in for more info.
I've seen other clutches where the center was offset and failed around 30-40k. (not hondas)
identical to this
webby is offline   Reply With Quote
Old 05-29-2007, 12:40 AM   #10 (permalink)
Replaced with stock components.
Old 05-29-2007, 12:46 AM   #11 (permalink)
articsilber323's Avatar
ide be showing that to honda
articsilber323 is offline   Reply With Quote
Old 05-29-2007, 01:22 AM   #12 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
Thanks again for the help blueroadster! Powershifting.. no never powershifted once in my life.. too scared too. I know I miss shifted early on when I first got the car over a year and a half ago because this is my first manual tranmission car. And no one test drove my car.
I do drive a lot, as I use my car for my job. Have I launched.. maybe a handfull at most.. I don't like to launch to be honest with you. I do downshift a lot. I will be cutting the downshifting a lot. I'm pretty sure I do downshift in excess at times.
No it has not been tracked but most of my driving is spirited.
Clutch disc actually had approx. 50% life in it left but as you can see it is unusable due to other damage. I'm sure it wouldn't be as bad as when I first noticed the problems but money to get a new clutch and time to get it installed was hard to come by.
Car drives like its new.. all gears engage like a hot knife thru butter. I know I'm relatively new to MT cars have a 18months experience now... but I don't abuse my car.
CliftNotes::
A few launches
Excessive downshifting
Maybe miss shift but that was when I first got the car
Exedy OEM Replacement
Thanks again blueroadster! I'm once again a happy Si owner
|108K Miles|I beat my tires harder than i beat my meat
ryryninja is online now   Reply With Quote
Old 05-29-2007, 01:31 AM   #13 (permalink)
fuller083's Avatar
Damn... This is just the post I needed. My clutch blew on me last Friday night on my way home from Atlanta. I had to call a tow truck and they towed it to a Honda dealer around where I was. The car is still there and they say I need a new clutch disc, throwout bearing and pressure plate.. I'll try to post pics of my disc as well, if they give it back to me. How much did this run you if you don't mind me asking? They are quoting me around 875 bucks...
fuller083 is offline   Reply With Quote
Old 05-29-2007, 01:42 AM   #14 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
Well it depends if you plan on going OEM.. check on ebay for clutch kits by exedy for rsx type-s.
I got mine for 138 shipped. Comes with pressure plate, flywheel, throwout bearing, alignment tool and I think it came with a pilot bearing too right blueroadster?
And blueroadster, his neighbor and myself installed it so no labor fee.
Old 05-29-2007, 08:30 AM   #15 (permalink)
PSU Pinoy PSU's Avatar
Eric
If he was powershifting, he would have thrown his gears out along with the clutch. But as you can see, just clutch problems.
PSU Pinoy PSU is offline   Reply With Quote
Old 05-29-2007, 08:32 AM   #16 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
oh and btw.. i saw blueroadster's ride... absolutely sick. didn't get to go for a spin.. but I will next time. it was already late.
Old 05-29-2007, 10:49 AM   #17 (permalink)
Originally Posted by webby
in for more info.
identical to this
I'll post s PIC of my stock clutch later today. It looked fine and only had 7k miles on it before removal.
Old 05-29-2007, 02:49 PM   #18 (permalink)
Yup...The pilot bearing was also included.
Old 05-29-2007, 07:36 PM   #19 (permalink)
Here are two PICs of my stock clutch removed after about 7k miles. As you can see, the gear is centered perfectly (it looks just a tad bit off, but that was because I did not align the camera dead center when taking the PIC).
First side:
Other side:
Old 05-29-2007, 08:12 PM   #20 (permalink)
adoBoy619's Avatar
Rollin
good thing with the labor free...btw..if you didnt go OEM, what other good options?
adoBoy619 is offline   Reply With Quote
Got Clutch? SacrificeTheory Driving Experience 37 07-15-2007 10:04 PM
2 quick questions on heel-toe and double clutching Asian Hamster Autocross & Sanctioned Drag Racing 61 05-02-2007 02:10 AM
Squeaky clutch? bung_goo Civic SI 17 03-07-2007 01:19 PM
Double Clutching WTF?? MADDOGSI Autocross & Sanctioned Drag Racing 46 12-19-2006 04:28 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 08:34 AM
