Old 05-23-2007, 01:55 AM   #1 (permalink)
steven
2007 civic automatic to standard help!!!
does anyone know how much it would cost to swap a from auto to standard in a 2007 civic. and what would you be your steps in making a drastic speed change. appreciate any help i can get!!
dobojoko is offline   Reply With Quote
Old 05-23-2007, 02:03 AM   #2 (permalink)
Tim
Well I suggest your first step is take your car to the dealership and trade the bitch in for a Civic with a MT.
Not to be obnoxious or anything.
trogers8 is offline   Reply With Quote
Old 05-23-2007, 02:11 AM   #3 (permalink)
06civictx's Avatar
Tim
yeah swapping it would be a bitch,i suggest taking it to a dealer and doing the trade,i think you'd have to swap the engine as well not sure though,but if you plan on swapping both,K24 ftw
06civictx is offline   Reply With Quote
Old 05-23-2007, 02:26 AM   #4 (permalink)
dentrecords's Avatar
Moved to the correct forum.
Good luck with that.
Originally Posted by 2fast4u2
yee hawww
Old 05-23-2007, 02:35 AM   #5 (permalink)
ballorfall's Avatar
yep, trading it in for a manual is the best way. too much labor, parts and time is put into it. Its a new car so it be hard to find spare parts to swamp it even if you can it probably be brand new so itll cost a lot unlike the older ninety something civic
ballorfall is offline   Reply With Quote
Old 05-23-2007, 02:41 AM   #6 (permalink)
new_with_civics's Avatar
Jorge Peņa
think about it... i dunno in the states but here in mexico the manual is cheaper than the auto, if it is a 2007 why dont you just trade it for a manual? i mean maybe you will end up paying the same for swaping than for trading it... plus you will get a new car hehe again....
new_with_civics is offline   Reply With Quote
Old 05-23-2007, 03:05 AM   #7 (permalink)
LoverOfCivics's Avatar
Javier
LoverOfCivics is offline   Reply With Quote
Old 05-23-2007, 11:33 AM   #8 (permalink)
volvo9's Avatar
Andrew
Start car.
Drive to dealer
Make a deal on new 07 Civic MT
Sign papers
Drive away
Your done!
In all seriousness, it's a LOT of work and a lot of money to put into such a new car, it's going to be cheaper to trade it.
Now if this was a 91 with 20k miles on it and it was in mint condition then a swap is certainly something that's doable. I swapped a manual into my ex 94 Volvo 940 Turbo, it was a straight forward swap, remove auto, insert manual and all parts removed from parts car. Nowadays you have to change computers, engine wiring harnesses, subframes, exhaust, alllll sorts of things, it's just not worth it.
Old 05-23-2007, 02:08 PM   #9 (permalink)
954K20_SI's Avatar
...don't Bother, Trade!
954K20_SI is offline   Reply With Quote
Old 05-23-2007, 03:06 PM   #10 (permalink)
jolus's Avatar
Gran A2
What everybody above said.
jolus is offline   Reply With Quote
Old 05-23-2007, 03:16 PM   #11 (permalink)
rivas240sx's Avatar
Christian
Manual R18s are hard to find, I had to look all over Houston and finally found one, they have significantly more pick up than the Automatics, and more fun to drive IMO, but they are difficult to find here in Houston. They are slightly cheaper not much and they don't get as good mpg as the Automatics because they have 1 less gear in the trany, which means they run at higher RPMs in the highway. Love mine. hope this helps
rivas240sx is offline   Reply With Quote
Old 05-23-2007, 04:17 PM   #12 (permalink)
Tim
Actually, just a correction, the Auto and the MT have the same amount of gears, 5, but the Auto is able to run at a higher gear ratio allowing it to run lower RPM's at high speeds giving it the additonal 2 MPG on the HWY.
Old 05-23-2007, 04:36 PM   #13 (permalink)
rivas240sx's Avatar
Christian
Ok, thanks for the correction, I knew it had something to do with the gears. But the extra pick up is nice definitively worth giving up the MPG
2007 Civic LX Automatic Question oates77 Mechanical Problems & Technical Chat 8 03-27-2007 02:39 AM
HONDA--- MODEL-YEAR-ENGINE-CHASSIS BATANG CITY JAIL Garage 1 01-26-2007 06:20 AM
Pontiac G6 vs. Honda Civic GlennS Garage 22 12-15-2006 02:51 PM
