Old 05-22-2007, 08:32 PM   #1 (permalink)
VSA Issues
My VSA, !, Brake and ABS lights randomly flashes while driving under normal circumstances. This all started after a foglight install gone bad. Cut some
wires, blew some fuses you know. My wife crunk up the car while the intake was apart and threw CEL. I unhooked the battery and got rid of the CEL. But I cant get rid of the other alerts? Any suggestions??????????
07si&06wrx is offline   Reply With Quote
Old 05-22-2007, 08:34 PM   #2 (permalink)
Excalibur's Avatar
Jeremy
Start with all of the fuses. Alot of probs electrically are due to either fuses or grounds.
Old 05-22-2007, 09:33 PM   #3 (permalink)
Ill try the fuses
Old 05-22-2007, 10:00 PM   #4 (permalink)
Not going to get much help to your problem unless you add more details.
blueroadster is offline   Reply With Quote
Old 05-22-2007, 11:30 PM   #5 (permalink)
...I unhooked the battery and got rid of the CEL...
I wonder why people insist on this method. All you did was tell the computer that it didn't see what it saw; you didn't solve the problem. The worst part is that, now, no one can diagnose this problem based on what the computer saw (because it was told to forget).
Incubus is offline   Reply With Quote
Old 05-23-2007, 12:56 PM   #6 (permalink)
Disconnecting the battery will not remove all DTCs (ABS DTCs are an example of ones that remain stored).
Old 05-23-2007, 10:07 PM   #7 (permalink)
I know what the CEL was from. Like I said my wife crunk the car up while the intake was apart and the O2 censor was out. In my subaru disconnecting the battery and pressing the brake in to drain the residual power resets the ecu
Oh and I wasnt that concerned about the CEL. Was more worried about the vsa flashing. I messed up and cut a wire that I wasnt suposed to cut. It was a red wire behind the kick panel. But I properly reconnected the wires with butt connectors. so other than that I cannot think of how a foglight install can affect something like ABS or VSA??
Anyways I took the car to the dealer today. They are keeping it over night. should find out something in the morning.
Old 05-24-2007, 12:49 AM   #8 (permalink)
Got it. When you said "crunk", I thought you were using slang to tell us that she somehow broke the car. I know now that you mean the past tense of crank. I hope the dealer doesn't charge you too much for their troubles.
Old 05-24-2007, 11:52 AM   #9 (permalink)
Ok the dealer said that they have to replace the ABS module? And it is covered under warranty. I guess that the fog light install and the VSA/ABS malfunction was just a crazy coincidence. Will post updates for future issues
Issues with changing seats in my '07? wildkatz42 Introduction & Pictures 6 09-10-2007 02:57 AM
IMPORTANT: Fuel Return Kit and Fuel Filter Issues blueroadster Forced Induction And Nitrous 196 04-27-2007 02:09 PM
Canada VSA? chanchan Civic SI 4 03-08-2007 08:47 AM
Summer tires + snow = VSA saved my ass! letsgoflyers81 Civic SI 11 01-21-2007 01:28 AM
VSA Light During V-tec? GeezerSi Civic SI 30 11-15-2006 06:04 PM
