Old 05-22-2007, 07:32 PM   #1 (permalink)
Drew303's Avatar
Clunk from front end.
I am starting to hear a clunk that sounds like its coming from the left front of my car. It happens sometimes when I hit a bump, or take a hard right turn. Does anyone else notice this in their car?
Drew303 is offline   Reply With Quote
Old 05-22-2007, 07:50 PM   #2 (permalink)
Excalibur's Avatar
Jeremy
What causes the clunk?
Old 05-22-2007, 08:28 PM   #3 (permalink)
Drew303's Avatar
Old 05-22-2007, 11:00 PM   #4 (permalink)
xmx250's Avatar
i'm having the same exact problem......
i get a clunk from under the left hood area when i hit a bump or take a hard right. i'm debating taking it to the dealer but it doesnt always happen, its kind of look cracking one of your finger joints, it happens only sometime.......
xmx250 is offline   Reply With Quote
Old 05-22-2007, 11:14 PM   #5 (permalink)
Englishe30's Avatar
Mark
I get it 2....
Englishe30 is offline   Reply With Quote
Old 05-22-2007, 11:25 PM   #6 (permalink)
Me too. There's at least one other thread about this. I'm doing my best to figure it out with my limited resources.
Incubus is offline   Reply With Quote
Old 05-23-2007, 04:38 AM   #7 (permalink)
same problem here
Inertia_Rec. is offline   Reply With Quote
Old 05-23-2007, 09:51 AM   #8 (permalink)
TUK0NG's Avatar
i have that problem too but i hear mine on the right front side
check this thread guys Sedan, clunk noise from right front
TUK0NG is offline   Reply With Quote
Old 05-23-2007, 10:00 AM   #9 (permalink)
watch for gestapo
Chase's Avatar
Chase
yeah damn I thought it was Me, im getting it from the front right side?
Chase is offline   Reply With Quote
Old 05-23-2007, 10:00 AM   #10 (permalink)
Taff7Si's Avatar
Same thing here (front left). Have heard it going over a small curb usually, also on turn-in on ramps.
Taff7Si is offline   Reply With Quote
Old 05-23-2007, 10:22 AM   #11 (permalink)
Excalibur's Avatar
Jeremy
Anyone think it might be the struts?
Old 05-23-2007, 10:42 AM   #12 (permalink)
htec17's Avatar
are you guy driving 2 or 4 doors and what side are you all hearing it fromfront or back?
htec17 is offline   Reply With Quote
Old 05-23-2007, 11:09 AM   #13 (permalink)
pure2.0's Avatar
Got it as well sometimes...
pure2.0 is offline   Reply With Quote
Old 05-23-2007, 01:08 PM   #14 (permalink)
Englishe30's Avatar
Mark
the sound is coming from somewhere up front....4dr
Old 05-23-2007, 01:29 PM   #15 (permalink)
TUK0NG's Avatar
non Si sedan here, right front
Old 05-23-2007, 01:38 PM   #16 (permalink)
skandal57's Avatar
It may be a motor mount thats faulty. i had a clunking sound over particular bumps that was pretty audible. i brought my car back and after a full day of 2 honda master techs checking everthing it has been determined a faulty right side motor mount. im picking my si up here in an hour os so and i can shed more light on exactly what was wrong. there is a bulletin that honda techs have access to in order to help diagnose there job and help others to as well. there is one about this right side mount.
skandal57 is offline   Reply With Quote
Old 05-23-2007, 02:37 PM   #17 (permalink)
pure2.0's Avatar
Damn it! I just drove around for a while and had a loud clunk/rattle from the left side twice....all of 3700 miles on the Si....
Old 05-23-2007, 08:14 PM   #18 (permalink)
watch for gestapo
Chase's Avatar
Chase
Honda has a TSB for the following vehicles. This only applies to Si Coupes. there are several other affected models too including the FA5 So make your dealer find it.
TSB # 06-061
VIN range # 0001 - 3185
Old 05-24-2007, 04:20 PM   #19 (permalink)
htec17's Avatar
If you havea noise from the right side front.the noise is coming from the pass side motor mount. if you have a clunk noise in the front on both side that is the bump stops
Old 05-24-2007, 04:31 PM   #20 (permalink)
Too Sleepy.
thatsnotstock's Avatar
does it sound/feel like its coming from the wheel well?
check the brake caliper. My Sentra SE-R had this problem...turns out one of the caliper bolts had sheared off, causing the entire mechanism to wiggle and clunk.
thatsnotstock is offline   Reply With Quote
CSX Front End Conversion tomasro Exterior Style Mods 113 11-15-2008 01:06 PM
Pop from front end . . . new struts? bluesunit Civic SI 12 08-17-2007 09:02 PM
Front end problems? Nathan Mechanical Problems & Technical Chat 0 03-06-2007 01:17 AM
Front License plate kdb California North 9 09-21-2006 04:40 AM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 03:32 PM
