Old 05-22-2007, 03:37 PM   #1 (permalink)
LoverOfCivics's Avatar
Javier
Green Light?
Alright ive noticed that i cant turn off the green light that has the man and the arrow pointing at his head dont know what thats called but i know its the vent control, but i cant seem to turn this off and when i drive air comes through the vents and but when i slow down the air also slows is this normal? its cool if its not wasting gas by using the ac
LoverOfCivics is offline   Reply With Quote
Old 05-22-2007, 03:58 PM   #2 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
That's just the circulation mode, where air is moving to your face. If you don't want to blow in your face, you'll have to also press the recycle air mode to block off the vents that shoot air into your face. That's what I do, but I'll still have the windows down for air circulation.
Old 05-22-2007, 05:13 PM   #3 (permalink)
WooooHooooo
darna's Avatar
Ate Vi
it should be on almost always... says the manual!
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline   Reply With Quote
Old 05-22-2007, 10:46 PM   #4 (permalink)
Javier
is it wasting gas?
Old 05-22-2007, 10:46 PM   #5 (permalink)
Javier
or is it just blowing from the outside?
at whatever speed i go?
Old 05-22-2007, 10:48 PM   #6 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Short answer, no. If the speed of the fan is set to zero, then no, especially if the temperature is on cold. If you have the AC or heat on, then yes.
Old 05-22-2007, 11:31 PM   #7 (permalink)
I think it is meant to be for the man, he def gets the arrow
xxhaimbondxx is offline   Reply With Quote
Old 05-22-2007, 11:32 PM   #8 (permalink)
i hate how the fans blow air when it is set to OFF. If the knob is turned to the red (hot) side my car heats up fast (inside)...i just turn it to blue and push the feet only button
i wish u could completely turn off the heating/cooling
CGNY is offline   Reply With Quote
Old 05-22-2007, 11:47 PM   #9 (permalink)
TJ213's Avatar
is it the fan blowing? I always thought it was just the air being pushed into the car because you're moving
Old 05-23-2007, 12:31 AM   #10 (permalink)
feels to me like its blowing as I can still feel it when i'm not moving (very lightly), some of it is the air being pushed but you can feel a difference if u change from hot to cold...i'm gonna give honda a call thursday
Old 05-23-2007, 01:12 AM   #11 (permalink)
There's a vent in the trunk for circulation, honda must have had problems with people suffocating or something. Anyways, set the circulation mode to "recirculate" which has an amber light, that way no outside air is coming in. I can't believe you're calling honda for something like that. It should be common sense, green means "open/outside air" so naturally, air will travel into the cabin.
Old 05-23-2007, 01:56 AM   #12 (permalink)
Bootsie's Avatar
Brooklynn
I know that if you have Max AC on it will not let you move it from the face vents, or turn the recirculation mode off.
Bootsie is offline   Reply With Quote
Old 05-23-2007, 02:17 AM   #13 (permalink)
How does having the temperature set to hot use extra gas?
dextor is offline   Reply With Quote
Old 05-23-2007, 02:27 AM   #14 (permalink)
Javier
Please lets keep it to understandable sarcasm
Old 05-23-2007, 02:31 AM   #15 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
I stand corrected.
Old 05-23-2007, 05:31 PM   #16 (permalink)
the only reason i was gonna call honda is because at least mine is more than outside air, it is actually heating or cooling the passenger compartment
U.S. & Canadian Tint Laws jc21 Inside and Out 42 11-24-2008 05:46 PM
HID Retrofit Progress Tim Lighting, H.I.D.'s, & Neon 106 08-02-2007 02:04 PM
Fog light MOD? freeurmind69 Lighting, H.I.D.'s, & Neon 0 11-25-2006 12:22 AM
Save the Light fiji06si13 Water Cooler 4 10-12-2006 10:18 PM
want to own luke's light saber? webby Water Cooler 6 07-11-2005 09:07 PM
