Old 05-21-2007, 11:39 PM   #1 (permalink)
Grinding My Gears!
i purchased my 07 SI no more then a week ago..when i drove it outta the lot with only 10kms on it and its got about 500kms on it...everything was fine my gears didnt grind! but now when i shift in to gear from neutral it grinds just a little, it dosnt grind all the time just sometimes. could it be clutch, transmission fluid, tranny?? what could it be? please i need some help! Thanks
BlueCivicSi is offline   Reply With Quote
Old 05-21-2007, 11:47 PM   #2 (permalink)
Tastycakes's Avatar
If its 3rd then its normal. Either go back to honda and ask them for the new manual transmission fluid or change to GM synchromesh or Amsoil. A lot of manual trannys come over filled too, another thing to ask them to check.
If its NOT 3rd gear then take it right back to the dealer to get it fixed.
Got any more details on it, like which gears or anything.
Tastycakes is offline   Reply With Quote
Old 05-21-2007, 11:47 PM   #3 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Is it one gear in particular? You should start by swapping out the MTF. Your case sounds different though, almost as if you have bad synchros.
Old 05-21-2007, 11:51 PM   #4 (permalink)
TJ213's Avatar
this may be a little off topic, but my 3rd gear kind of sounds like it has a short mini grind when I shift into it, just like a grindy klunk, is this normal?
Old 05-21-2007, 11:52 PM   #5 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Did you change your MTF. I think it's normal. Third gear sort of has two stages, where it'll go in, but you know it can go in further, so you put it into neutral and go back into third.
Old 05-22-2007, 12:18 AM   #6 (permalink)
Shiting on my civic isn't as smooth as I like sometimes. It feels notchy at times...maybe this is what you're referring to? Grinding gears is actually quite loud and very distinct.
dextor is offline   Reply With Quote
Old 05-22-2007, 12:23 AM   #7 (permalink)
dnbsi is offline   Reply With Quote
Old 05-22-2007, 12:39 AM   #8 (permalink)
TJ213's Avatar
my MTF is still the origional stuff, I get all the way into 3rd, and my 3rd isn't really grinding (I know what that sounds like), but its making a wierd, grinding like klunk sound when the shifter hits the top.
Old 05-22-2007, 01:03 AM   #9 (permalink)
Will06SI's Avatar
Will
My 2cd gear is notchy alot you aint the only 1 3rd hasent grinded in a while.
Will06SI is offline   Reply With Quote
Old 05-22-2007, 01:06 AM   #10 (permalink)
07SiCivic's Avatar
Daniel
Originally Posted by dnbsi
lol!!!!!!!!!!!!!!!!!!!!!!
i think he meant shift
07SiCivic is offline   Reply With Quote
Old 05-22-2007, 01:08 AM   #11 (permalink)
jballer187's Avatar
Jonny
LMFAO!
jballer187 is offline   Reply With Quote
Old 05-22-2007, 01:40 AM   #12 (permalink)
chilipepper's Avatar
Chuck
Normal? Common, yes, but not normal...
Do what Tastycakes says...
chilipepper is offline   Reply With Quote
Old 05-22-2007, 01:44 PM   #13 (permalink)
HAHAHAH I just realized i typed SHITTING HAHAHAHA
Old 05-22-2007, 01:45 PM   #14 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
I missed that typo as well.
Old 05-22-2007, 07:34 PM   #15 (permalink)
When I first bought my 06 it grinded 2nd and 3rd occasionally. Now at 23k the 2nd grind is gone but 3rd is still sometimes stiff. The application of a short shifter and the corsport aluminum shift bushings have made my shifter more positive and greatly less prone to grind. I will be going with the gm synchromesh(with friction modifiers). much harder to find than standard synchromesh.I hear this stuff is great.
Budokha is offline   Reply With Quote
Old 05-23-2007, 12:47 AM   #16 (permalink)
where can i find this "GM synchromesh" MTF and how much is a shortshifter? and what kind?
Old 05-23-2007, 01:09 AM   #17 (permalink)
CraigSi4's Avatar
haha did anyone else think of family guy when they first read this topic?
http://youtube.com/watch?v=_zIzciYwGHM
edit: btw the end of the vid is hilarious, chris going... go on.
CraigSi4 is offline   Reply With Quote
Old 05-24-2007, 01:54 AM   #18 (permalink)
lol actually yah i was gonna name the topic "you know what really grinds my gears"
Grindin gears like WHOA!!!!!! Yo Nadz Civic SI 42 02-16-2008 12:50 AM
Rev Matching/Gear Grinding CaliGuy Garage 46 08-31-2007 07:13 PM
cam gears?? aodmisery Bolt-Ons And All-Motor 4 02-22-2007 08:08 PM
Pulling and grinding noises Sirbelch Suspension and Brakes 0 02-02-2007 10:18 PM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 11:38 AM
