Got tint, now radio sucks - 8th Generation Honda Civic Forum
Old 05-21-2007, 01:53 PM   #1 (permalink)
Quantum's Avatar
Last weekend I finally got My Si tinted, 50% on rear and sides with metallic tint. Since then I've noticed my radio reception sucks, especially AM. FM sounds about the same, maybe slightly crackly, but my AM reception is terrible now. It sounds as if the radio stations that used to come in perfectly clear are 500 miles away and are barely audible. Is this due to the metallic tint on the rear window, or is it just something wrong with the antenna?
Quantum is offline
Old 05-21-2007, 02:29 PM   #2 (permalink)
Ryd1ZZ's Avatar
Ryan
When I got my tint done the guys at the shop told me that because our antenna is built into the rear window, any tint with metal would mess up my reception and to go with a non-metallic brand (cost more). I thought it was some BS to get me to pay more but he gave it to me for the same price as the other stuff so I went for it. I still wasn't sure the other stuff would cause an issue but this may be proof. If it's really bad maybe you can go back and get it re-done with the non-metallic stuff for a discount?
Just my .02
Ryd1ZZ is offline   Reply With Quote
Old 05-21-2007, 03:11 PM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
it is the metallic tint...
Old 05-21-2007, 03:13 PM   #4 (permalink)
Excalibur's Avatar
Jeremy
metallic tint is always bad. It also messes with radar detectors.
Old 05-21-2007, 03:16 PM   #5 (permalink)
rmfa's Avatar
Ronnie
Yep, I used carbon-based tint on my car. Everything is just as it was from factory. Its more expensive but it looks great and doesn't block anything but sun and some heat...
Old 05-21-2007, 03:22 PM   #6 (permalink)
honestly though....do you REALLY listen to am radio???
paakaula is offline   Reply With Quote
Old 05-21-2007, 03:33 PM   #7 (permalink)
rmfa's Avatar
Ronnie
Old 05-21-2007, 03:36 PM   #8 (permalink)
FusionSi11's Avatar
Reese
+1 carbon-based is the way to go....no trouble with mine.
i do....ESPN radio and Cubs games on the AM radio.
FusionSi11 is offline   Reply With Quote
Old 05-21-2007, 03:40 PM   #9 (permalink)
Rems07si's Avatar
Remy
Just my .02
i never herd that before in my life i think he was blowing smoke up your you no what
Rems07si is offline   Reply With Quote
Old 05-21-2007, 03:42 PM   #10 (permalink)
mattSi's Avatar
Matt
Get XM or Sirius... problem solved
mattSi is offline   Reply With Quote
Old 05-21-2007, 03:55 PM   #11 (permalink)
rmfa's Avatar
Ronnie
Its very true. There are a few threads on this already...
Old 05-21-2007, 04:00 PM   #12 (permalink)
CrAsian's Avatar
metallic tint is usually blamed for bad radio reception (urban legend, placebo effect, i don't know for sure). i believe that it would screw with reception and it would be extra bad for our civics since our antennas are built into the rear window. that being said, if you wanna read more about it, just search on google for metallic tint radio and you'll see a bunch of people compaining about the same thing.
CrAsian is offline   Reply With Quote
Old 05-21-2007, 06:44 PM   #13 (permalink)
Jardiniboy's Avatar
Jasten
Call mythbusters. Haha
Old 05-21-2007, 07:30 PM   #14 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
AM radio is a hard frequency to recieve from the get go. Every time you are near transformer or any electrical field that is emitted it can effect AM stations. The metalic tint can be playing a role. But the tint guy might have disconnected a wire to put the tint on or he could have dammaged the copper runs (antenna) on the glass with any kind of tool that he used to smooth or trim the tint to the glass. Take a look at things if all is intacked then the tint is the culpret.
RIP Bernie Mac, Ricardo Montalban, Lux Interior, Dom Deluise, M.J., Ed Kennedy, DJAM, Patrick Swayze, Brittany Murphy...
fiji06si13 is offline   Reply With Quote
Old 05-22-2007, 03:06 PM   #15 (permalink)
Quantum's Avatar
Well FM still sounds pretty good, it is only a little bit worse. FM is usually much more sensitive to bad reception, especially with stereo channels. So if the antenna was disconnected or damaged, I would think the FM would be inaudible. However because it is mainly AM that is not working, my guess is that the tint must be grounded to the car some how and is absorbing or interfering with the AM signals. And yes I do listen to AM all the time for news and traffic in the morning and the talk radio shows in the afternoon. The AM station that I listen to is located only a few miles away downtown and always came in perfectly clear before I got the tint.
I called the tint place and they said to come by any time and they would take a look at it. So hopefully they will offer me a different kind of tint.
Quantum is offline   Reply With Quote
Old 05-22-2007, 09:14 PM   #16 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
AM and FM use different locations on the glass plus ever use tin foil on an old radio's antenna to get better FM reception...if anything the FM will come in better.....
Old 05-22-2007, 09:45 PM   #17 (permalink)
TJ213's Avatar
Originally Posted by mattSi
Get XM
, probably cheaper than re-tinting your window, I got mine for $20, and you get more music and stuff too.
Old 05-23-2007, 12:34 PM   #18 (permalink)
07civicex's Avatar
Matt
Yeah, the metal tint helps to create a "faraday cage" - it blocks out incoming singals. you have to remeber that an AM signal is an amplitude modulated signal which means that is picked up by your car's lines in the glass window- the metalic tint unifies all of the metal lines, and it cant pick them up very well....
07civicex is offline   Reply With Quote
Old 05-23-2007, 07:17 PM   #19 (permalink)
DetachmentBravo's Avatar
William
Somehow I don't think that changing the electromagnetic characteristics of an automobile will effect its RCS (Radar Cross Section).
DetachmentBravo is offline   Reply With Quote
Old 05-23-2007, 09:03 PM   #20 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
wow getting real technical here....basicly remove the tint and see if you get better reseption....
DIY: Aftermarket radio Install in an EX xtv-sidecar Audio 422 02-01-2012 09:17 PM
U.S. & Canadian Tint Laws jc21 Inside and Out 46 06-17-2009 05:33 PM
Factory Amp and AVN6610 nawlinsborn73 I.C.E., Electrical, Security, & Navigation 5 03-26-2007 01:58 AM
