Old 05-21-2007, 11:21 AM   #1 (permalink)
comptech ss problem
hey guys.. i have had the comptech ss, or sTs i guess i should say, for awhile now, but for the last month or two i have noticed a slight problem. first off, its great, i love the shorter throws, altho i am alrdy used to it and want shorter ones, but thats another story haha.. okay, well the problem is that if i go into 5th or 6th, or reverse, basically if i bring the shifter all the way to the right, and then come back to the left to go into first or second, or not even into gear, just bring it back all the way to the left, it makes a slight knock noise and i can feel it notch a tiny bit just about when im all the way over to the left.. this problem is kinda hard to put into words but hopefully i explained it as best as i could.. i have taken off the shift boot and looked inside to see if i can see anything catching or if anything looks out of place, and everything looked perfect, and i installed it myself, with a friend, so i know the basic concept of the ss, and stuff. any ideas what it could be?
sloppytot is offline   Reply With Quote
Old 05-21-2007, 11:23 AM   #2 (permalink)
Excalibur's Avatar
Jeremy
Maybe lubrication????
Old 05-21-2007, 11:26 AM   #3 (permalink)
i thought of that, but what part exactly you think should be lubbed?? the main part that i put the SS piece on?
Old 05-21-2007, 12:04 PM   #4 (permalink)
ill try that this evening.. any other ideas anyone?
Old 05-21-2007, 01:56 PM   #5 (permalink)
pure2.0's Avatar
I had problems with mine contacting the black plastic shifter base and had to file a bunch of material out to make the space/hole bigger. Also, I noticed that installing my SS really took one of the cables to its max amount of travel and made things difficult for a while. Also, see if the SS end with the blue cap is not binding/getting stuck on the black plastic end of the lower cable, as the clearance is tight between where the ball with the blue cap pivots. -Don't know if any of that made sense......
pure2.0 is offline   Reply With Quote
Old 05-21-2007, 02:31 PM   #6 (permalink)
Excalibur's Avatar
Jeremy
Is there anyplace that still sells the comptech ss?
Old 05-21-2007, 02:44 PM   #7 (permalink)
pure2.0's Avatar
I still see them on ebay once and a while.....
Old 05-21-2007, 02:47 PM   #8 (permalink)
thanks pure, i will check all that.. u dont happen to have any pics of where exactly u filed down do u?
DIY: Comptech SS Install NBP~FG2 Engine 50 12-05-2008 03:41 AM
stage 2 comptech release info!! OneSi Forced Induction And Nitrous 82 09-05-2008 11:06 AM
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 05:27 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
Comptech my ARSE!! 07SiGuy Suspension and Brakes 2 10-27-2006 12:39 PM
