Old 05-19-2007, 11:34 PM   #1 (permalink)
projectprelude's Avatar
Aaron
Vibration
ok guys why would i have a vibration after 105mph....i dont really know...tires?alignment? help me out
projectprelude is offline   Reply With Quote
Old 05-19-2007, 11:34 PM   #2 (permalink)
oversized wheels. (aftermarket wheels)
inyong1988 is offline   Reply With Quote
Old 05-20-2007, 02:47 AM   #3 (permalink)
WooooHooooo
darna's Avatar
Ate Vi
you might need some hub centric rings if u have aftermarket wheels or could be an alignment problem or could be balancing.
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline   Reply With Quote
Old 05-20-2007, 09:31 PM   #4 (permalink)
Its a special feature on new Hondas, after 100 MPH it turns on a special vibrating massager to put you to sleep. It's all about luxury.
xxhaimbondxx is offline   Reply With Quote
Old 05-21-2007, 02:45 PM   #5 (permalink)
Aaron
well the thing is it didnt do it before....i just started one day....tires have been rotaded...
Old 05-21-2007, 02:48 PM   #6 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
If the wheels have just been rotated, then I would start diagnosing the issue by either reversing the order and seeing if it goes away or jump straight to balancing it.
What was the interval you waited in order to have them rotated? It's possible the tires have some serious tread wear and now that you've rotated, it'll shake.
Old 05-21-2007, 03:02 PM   #7 (permalink)
Excalibur's Avatar
Jeremy
It seems like alot of people have vibration issues or is it just me being a nervous nelly?
Old 05-21-2007, 03:04 PM   #8 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
I had mine over 100 mph a couple of weeks ago, and it was smooth and solid. More than likely it has something to do with the rotation. Probably tread wear and moving the tires into differnet positions at the corners.
Old 05-21-2007, 04:28 PM   #9 (permalink)
volvo9's Avatar
Andrew
Vibration issues at high speeds are susally due to balance. Your alignment has to be WAY off for it to cause a vibration.
This is a very common problem, it's just more pronounced on the civic since the suspension is so stiff. It's less noticable on a car with softer suspension.
Old 05-21-2007, 05:03 PM   #10 (permalink)
radiocontrolhead's Avatar
Danny
The speed limit is 65 MPH. I don't know why you're doing 105MPH.
Vibration in clutch pedal? SonicK20Z Mechanical Problems & Technical Chat 9 09-10-2007 12:04 AM
07 Civic Si Sedan Gas Pedal Vibration GoldenBoy Mechanical Problems & Technical Chat 3 06-21-2007 11:48 PM
Muffler hook vibration turbo311 Mechanical Problems & Technical Chat 2 03-18-2007 09:16 PM
C-pillar vibration behind SRS cover Occidio Mechanical Problems & Technical Chat 2 01-24-2007 01:51 PM
Vibration from the clutch. Marin Mechanical Problems & Technical Chat 8 09-01-2006 02:09 AM
