Old 05-16-2007, 12:24 PM   #1 (permalink)
26,000 miles and tires need replacement?
I've got an '06 LX sedan. The last time I had my tires rotated, the shop told me I needed new tires. Sure, typical shpleel from a tire salesman. Of course I declined. Well a couple of weeks ago I got a flat, and the shop that patched it told me the same thing. They even measured the tread in front of me and explained that the left front tire was significantly worse than the rest.
I left it at a Honda dealership this morning to have them inspect. Of course right off he told me "tires wear out, depends on driving patterns, blah blah" I told him to inspect it and if they couldn't find anything, I wanted a manager.
So what gives? I drive all highway miles and maintain the car like I should. The car doesn't pull like it's out of alignment. Anyone else had to replace tires early?
tadboy is offline   Reply With Quote
Old 05-16-2007, 12:32 PM   #2 (permalink)
watch for gestapo
Chase's Avatar
Chase
What size tires do you need man? I have a new job and can get Rims and tires on the cheap..
Chase is offline   Reply With Quote
Old 05-16-2007, 12:32 PM   #3 (permalink)
SiCali's Avatar
that isn't necessarily early for stock tires. stock tires from honda are known to wear down quickly. how often did you rotate the tires? uneven wear can be attributed to many factors such as aggressive turning/driving and not rotating your tires frequently (i think it's usually every 7500 mi, but not sure). if you want long lasting tires, get ones that are rated for higher treadwear. if they show you that your tires are bald (e.g use a penny), you definately should change them.
SiCali is offline   Reply With Quote
Old 05-16-2007, 12:35 PM   #4 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
Did you often rotate your tires? The tires from the factory suck. I was at 32,000 kilometers and my tires were at the end of its life.
Old 05-16-2007, 12:55 PM   #5 (permalink)
I've rotated 3 times since I got the car, around every 7-8k miles.
I think it's silly to expect them to be worn out, stock tires or not. My last car was a Prizm, and the stock tires lasted nearly 65,000 miles.
I'd let these tires go bald, but the car shakes so bad beyond 60mph, something's got to be done.
Old 05-16-2007, 02:11 PM   #6 (permalink)
07civicex's Avatar
Matt
I wouldnt complain- tires on the Corolla and Matrix last only 10-15K miles......
07civicex is offline   Reply With Quote
Old 05-16-2007, 02:24 PM   #7 (permalink)
volvo9's Avatar
Andrew
My mothers where trashed at 14k. Steel belts where about to show.
volvo9 is online now   Reply With Quote
Old 05-16-2007, 03:40 PM   #8 (permalink)
Ryd1ZZ's Avatar
Ryan
My dealership told me the stockers should only last about 20k miles. It's just another area the car companies shave off production price. When they DO put good tires on your stock car, you will pay for them(alot)
Ryd1ZZ is offline   Reply With Quote
Old 05-16-2007, 06:58 PM   #9 (permalink)
zenith931's Avatar
Yes, I AM A WOMAN!
Isn't that a sign that your alignment is out of whack? That would explain your tires wearing prematurely.
zenith931 is offline   Reply With Quote
Old 05-16-2007, 10:16 PM   #10 (permalink)
dominodave's Avatar
dominodave is offline   Reply With Quote
Old 05-16-2007, 10:32 PM   #11 (permalink)
n00b retro whore
ethlar's Avatar
Its actually more the softer, shorter life tires give the car a nice quiet ride that most people are looking for in their new cars. When you put on longer life tires you will notice that the road noise goes up. You get either quiet ride and short life or some road noise and long life
Old 05-17-2007, 10:57 AM   #12 (permalink)
If one tire is significantly more worn than the other three and the car shakes as you indicate it could have internal damage (broken, or shifted steel belt). The tire could look normal but be damaged. This is not uncommon. If the belt is not placed perfectly true abnormal wear patterns will happen. However, 26K miles isn't necessarily too early for a OEM tire to wear out and it depends heavily upon individual driving habits, maintainence e.g. rotation...checking tire pressure frequently etc.
targettuning is offline   Reply With Quote
Old 05-17-2007, 11:45 PM   #13 (permalink)
Update on the visit to the dealership. Nothing was wrong with the alignment. The balancing was off enough to cause the shaking.
They refused to do anything about it. As ethlar said, and the service agent confirmed, they put on cheap tires to bring down the costs, so expecting more than 30k out of these Turanzas is expecting too much.
Apparently the Turanzas have a bad rep. I priced new tires today at Discount Tire and Goodyear, and they said "oh yeah, those are $hit."
Given my other quirky problems with the car that Honda can't/won't bother fixing (rough idle, rev hang, notchy 5 speed, hesitation at full throttle to name a few), I'm probably just going to trade it in and look at Mazda or Nissan or something.
Old 05-18-2007, 03:37 AM   #14 (permalink)
280whp, 219tq, GReddy FTW
GalaxyGreySi's Avatar
Phil
I only got 12,000 miles out of the stock tires on my Si.
If you must whine about my Avatar, do it in this thread:
http://www.8thcivic.com/forums/showthread.php?t=35167
GalaxyGreySi is offline   Reply With Quote
Old 05-18-2007, 12:54 PM   #15 (permalink)
bsramzy's Avatar
u gotta be kidding
bsramzy is offline   Reply With Quote
Old 05-18-2007, 01:08 PM   #16 (permalink)
Will06SI's Avatar
Will
What were doing with them i have the all season stockers on my SI with 18k on them and they look great i drive 75% highway 25% street BTW ive only rotated them once =/
Will06SI is offline   Reply With Quote
Old 05-27-2007, 10:02 PM   #17 (permalink)
Most OEM tires suck and wear quick. This is especially true for cars like my wife's 05 corolla that has the suckiest tires man invented.
My wife has had 3 corollas new ranging back to 2000 and not one set lasted more than 20K. She drives real careful and does not speed.
I am quite surprised that the Goodyear RS-A's on my 06 are wearing well and still handling pretty good after 12K
Old 05-28-2007, 03:06 AM   #18 (permalink)
Tastycakes's Avatar
Yea summer tires right I rotated mine at 5k miles and the fronts were about half gone. I bet i wont get 15k out of em. On the other hand my moms caddy went 50k+ miles on her vogues
Tastycakes is offline   Reply With Quote
Old 05-28-2007, 04:08 AM   #19 (permalink)
Skylinegtr06's Avatar
edwyn(male)
Went to costco these tires are 205 bucks a pop holy SH(* I have to stop testing my suspension on turns
How many miles with the OEM tires on the SI ??? seaman Wheel And Tire Upgrades 24 05-25-2007 11:58 AM
Making an EX look like a DX (snow tires w/pics) GlennS Wheel And Tire Upgrades 2 02-10-2007 05:46 PM
Value of EX rims and stock tires with 18k miles? less Wheel And Tire Upgrades 4 08-10-2006 03:17 PM
