I changed to synthetic oil(AMSOIL & filter) at the beginning of April when the car had 5k miles. Today, I was checking the oil level to make sure everything was ok and was surprised that the oil level was very low (at the lower mark of the dipstick)
So I checked and rechecked to make sure..and it is definately very low. I went under the car and there are no oil leaks around the filter or drain bolt; also the space where I usually park my car and stays most of the time has no oil marks either..This isn't my first oil change and according to our manual it says to add 4.6 US qt (4.4 lt) to the Si..that's exactly what I did. what could be happening? I'm concerned if I add more oil I could mess up my car..has anyone ever had this issue before??
#5 (permalink) | |
#6 (permalink) | |
So, once you added oil to fill it up, did it stay full or you had to often add again before having to replace the oil? |
#7 (permalink) | |
#10 (permalink) |
I found with my Si Sedan that during the first 7000 or so miles that I had to add a bit of oil every week or so...but that now, at 15000 miles oil consumption has decreased to about nil.
FWIW I switched from factory fill to Mobil1 around 500 miles and then to Amsoil at 4588 miles. |
#11 (permalink) | |
really weird that this is happening..I can understand it being 1 qt low, but for the oil to drop to the lower mark of the stick?? |
#12 (permalink) |
Acorns!
There are a number of people who said they initially burned oil in their car.
Lost Oil during first 3k miles? Burning Oil and No leak~! Are you still burning oil? (SI only) there are a number of others on the site like this above. |
#14 (permalink) |
Kill Your Self Krew
my si takes 5.3 or so.
#18 (permalink) |
I switched to full synthetic on my first oil change and I have not had this problem. I use Penzoil Platnium. I gotta say I don't see myself ever using another motor oil. My oil level has stayed at the top of the dipstick just about everytime I check it. So so far so good. *knock on wood*
#19 (permalink) |
Kill Your Self Krew
4 quarts is not good.
#20 (permalink) |
![]() Join Date: May 2006
J. M. back by popular demand!
I am on my second change out with Redline 5-30 and I have to add about 1 qt between changes...In fact I just chenged it a few days ago...Drove it around right after (to get it hot), checked the oil level and I was low by 1/2 quart...and I added the exact amount of required oil...eh...I'll just add another 1/2 quart...Do be careful though! Over filling your oil could really f things up!
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
| Oil Life | Elmacho | Civic SI | 32 | 12-02-2008 03:01 PM |
| First oil change for an 06 Civic? | PhoenixDown | Mechanical Problems & Technical Chat | 70 | 09-04-2007 01:10 AM |
| Slick 50 Engine Oil treatment in Si | Chase | Civic SI | 12 | 04-04-2007 03:13 AM |
| noobie changing oil | Downpour | Do It Yourself Articles | 4 | 07-30-2006 03:09 PM |
| synthetic or regular oil | colecar | Garage | 13 | 07-03-2006 04:09 AM |
