Brakes!
Hello,
I hear a weird noise from under the car. It happens usually when I try to stop at stop signs or red light. While I am pressing the brake pedal, if I go over bumps and uneven surfaces, I hear a wierd noise from under the car. It is like ABS noise[like something is moving really fast under the car!]. I am not sure if it is ABS. This is happening on dry roads and I am not sliding at all. What do you think this is? Could it be something serious? Thanks, Amir Last edited by amirh; 05-09-2007 at 05:45 PM. |
It really sounds like ABS. I have this sewer that I run over everytime I go by my house and my brake pedal flops around and engages the ABS. Any sort of stopping on gravel would do the same thing. I'd suggest you take it to a back road and test it out, but I'm willing to bet it's ABS.
#5 (permalink) | |
Abs!
Second, assuming it is the ABS. Is there any solution to fix this? Is this a common problem? Thanks, Amir |
it makes sense the ABS is engaging, if the tire is in the air there is no traction, and ABS engages to keep it from stoping
solution, stiffer suspension and better tires may help I guess, but probably won't, there's really not much you can do, besides, its not like its a problem, ABS is there to help the car stop faster while maintaining control in real world conditions. |
#7 (permalink) | |
| Problem with the Brakes? | hatchbac_smokin_you | Mechanical Problems & Technical Chat | 11 | 01-05-2007 02:27 PM |
| Upgrading the brakes of a 2002 Elantra | uscgbeachbum | Garage | 0 | 12-20-2006 10:04 PM |
| Brakes upgraded to JDM Euro R Accord brakes | pengful | Suspension and Brakes | 32 | 08-19-2006 10:21 AM |
| weird anti-lock brakes? | carlossamano2004 | Suspension and Brakes | 17 | 04-30-2006 11:29 PM |
