Old 05-09-2007, 04:00 PM   #1 (permalink)
NcSi's Avatar
Bryan
gas pedal
Does anybody elses gas pedal click when you let off the gas? I dont rember if it used to it or not but for the last month its very noticble
NcSi is offline   Reply With Quote
Old 05-09-2007, 04:04 PM   #2 (permalink)
fernando47's Avatar
FERNANDO
my clutch pedal does that.
fernando47 is offline   Reply With Quote
Old 05-09-2007, 04:10 PM   #3 (permalink)
06blaksi's Avatar
I don't let off the gas
Old 05-09-2007, 04:11 PM   #4 (permalink)
poizun's Avatar
Dan
affirmative. mine does that too. i used to think it was my shoes until i changed my shoes. lol
poizun is offline   Reply With Quote
Old 05-09-2007, 04:25 PM   #5 (permalink)
illusionstwice's Avatar
The original --> "J" <--
mine doesnt, but my cluthc does. my doors click when there opened all the way. Just noticed it and dont know if it is normal.
illusionstwice is offline   Reply With Quote
Old 05-09-2007, 10:10 PM   #6 (permalink)
dude's Avatar
Mine clicks. I am sure it did not do that before, it started recently and it is annoying
dude is offline   Reply With Quote
Old 05-09-2007, 11:25 PM   #7 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
I'll check 2 morrow....
Originally Posted by ryker View Post
intial quality should be good when you spend 20K or more on a car. If I buy a 30.00 Polo shirt I damn well expect the buttons to stay put.
Originally Posted by fiji06si13 View Post
Well said..... now relay that message to honda......
RIP Bernie Mac
fiji06si13 is offline   Reply With Quote
Old 05-09-2007, 11:56 PM   #8 (permalink)
TJ213's Avatar
mine clicks slightly I think, but the thud of the gas pedal, and the exhaust overpowers it.
now the clutch...
Old 05-09-2007, 11:57 PM   #9 (permalink)
my clutch clicks.....i'm sure that is bad but how serious is this?...i'm so paranoid
cto424 is offline   Reply With Quote
Old 05-10-2007, 12:01 AM   #10 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
I think the clutch is going to click. Mine clicks when you press it.
Old 05-10-2007, 12:37 AM   #11 (permalink)
my gas pedal clicks too
yeppi is offline   Reply With Quote
Old 05-10-2007, 07:56 AM   #12 (permalink)
Yep, mine clicks.
rojadef is offline   Reply With Quote
Old 06-13-2007, 06:04 PM   #13 (permalink)
Duce2k's Avatar
Yep I have that gas pedal click, when I release the pedal, It may have something do with it being an electronic throttle, I'll have it checked when I go in for my service
Old 06-13-2007, 06:07 PM   #14 (permalink)
Dans_Si's Avatar
Same here. I check the nuts holding on the DBW sender and they were tight. It's something inside the sender on mine.
Dans_Si is offline   Reply With Quote
Help. Gas Pedal Removal wnorthern Do It Yourself Articles 13 10-09-2008 11:21 PM
07 Civic Si Sedan Gas Pedal Vibration GoldenBoy Mechanical Problems & Technical Chat 3 06-21-2007 11:48 PM
gas pedal lower than brake pedal? theprodigy Civic Coupe And Sedan 8 04-02-2007 11:15 PM
gas pedal noise jd74 Mechanical Problems & Technical Chat 3 04-22-2006 01:32 AM
loose gas pedal? LsedanX Mechanical Problems & Technical Chat 3 04-20-2006 10:00 PM
