#1 (permalink)
Center console and lower dash heating up.
My center cup holders, shifter and lower dash where really heating up bad. Si I decided to look into this problem.
I got into my center console and dash heat up problem today. Opened up the console and sure enough a 45 degree part of the duct had came loose. http://www.psyshack.com/duct1.jpg http://www.psyshack.com/duct2.jpg I put it back in its proper spot. Thumped it with my finger and it fell right back out again. http://www.psyshack.com/duct3.jpg So with that I went to get my drill and a shooter screw. Installed the screw. Zip Zing,,, Done. http://www.psyshack.com/duct4.jpg Whole project didnt take 30 mins from start to finish. Even had to pull the consel to retrive a clip that fell off from the top cover of the consel. Pulling the consel itself is easy as can be. Four screws, remove the cover under the dash on passenger side and to push locks one wire and its out of there. Dash has also cooled down alot. I couldnt see taking the darn thing into a dealer for such a stupid simple repair and improvement. ( ie the screw LMAO ) I hope this helps out. psy |
Webby's Minion
![]() Join Date: Mar 2006
Nikon Squad Member #8
Where and when were your sedans made? This could potentially be a recall item. I also have a sedan, but haven't noticed the problem. My EX AT sedan's final assembly point was Japan.
Next NorCal Meet - North Bay http://i79.photobucket.com/albums/j1...ser/GGBsig.gif - 8 t h g e n u s e r - |
1HG, I think America from what I searched. I have read 2 or 3 forum posts of this, I don't like the idea of being "screwed" after assembly. If I knew that was what he was going to do I would have complained and done it myself. Either way it is fixed now.
I have this same problem, been into the shop twice and they said (it's not that hot) we won't do anything about it, it's supposed to be that way. ARRRRG. I'm going to have to fix it myself I guess.
#10 (permalink) | |
My cup holders get warm, but I don't want to mess up my new car by getting into the shifter housing without knowing how to do so... Thanks! |
#11 (permalink) | |
So while holding the ducts together in their proper position (i.e. mated), I drilled a small hole through both of the black, plastic, duct parts and ran a #6 x 3/4 inch long stainless-steel screw through the small hole I made (even a half-inch screw would have done the job). Now the two parts stay together nicely! No more overheated Coke cans in my cup holders! That had been really annoying, to have overheated soda, etc. due to this design problem. I'm going to pass your post and pics on to my dealership service advisor, so they'll know. Thank you again, great post. Regards, Glenn in CT P.S. To get into the shifter console, I used the instructions in this post: Center Console removal for Aux input install For the AT, put the car in drive-D-to center the shifter over the metalic-looking, plastic trim ring you'll be removing: You can pop off that metal-looking, plastic trim ring around the AT shifter by getting your fingernails under its edges and lifting straight up. Then, again with your fingernails, start at the back of the black, plastic console and lift straight up, working from the back, towards the dashboard/stereo. Work it off slowly and soon you'll see the heater ducts as in psy's photos. Last edited by GlennS; 05-24-2006 at 08:35 PM. |
#14 (permalink) |
![]() Join Date: Apr 2006
Civic Type Stock
Hahah this is the first time I noticed this sticky and I have just noticed this last night too! Well my drinks have always been fine, but the plastic around the transmission (AT) got really warm last night (i thought maybe it was the light-up?) and only the left/driver's side. Also the air crank button ad maybe the temp button too got hot last night.
When I go in for my oil eventually, I will get the dealer to check it out along with the rattle, among others!
I crack nuts for a living |
#17 (permalink) |
Nathan Nightingale
OMG I thought the trans or engine was getting hot and heating the console up I am going to check this out and hopefully find this is the problem. I will let you all know.
Thanks, Nathan |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/3901-center-console-lower-dash-heating-up.html
| The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: 2006 Civic: Cup holders get hot--a fix. | This thread | Refback | 03-02-2008 12:13 AM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 03-01-2008 06:04 AM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | This thread | Refback | 02-20-2008 08:21 PM | |
| 2006 Civic: Cup holders get hot...a fix. | This thread | Refback | 01-22-2008 06:43 AM | |
| ClubCivicQuebec.com :: View topic - 8Th Gen FAQ | This thread | Refback | 12-08-2007 05:20 PM | |
