Transmission Whine.....
I have a 07 si sedan...in 3rd gear at about 29mph with light throttle input the trans whines. It does it in 6th at about 50 mph. Sometimes when I am in first it will do it loudly. I give it gas it goes away, I let off it goes away. It like a light throttle sweet spot. I'm gonna see if they will let me drive another si at work monday to see if it does the same thing....also, try this....bring your rpms up to 2500rpm and hold it there.....feel the vibration. A customer came in the other day complaining about this. We didn't have anymore si's on the lot so they asked me for my keys. Mine does it worse than his. Do it with the door open and put your hand on the door....its even worse.
#4 (permalink) | |
#5 (permalink) | |
Yep I've had the same issue since day one. It actually sounds like my car is a bit worse, especially in 1st and 2nd gear (at low speeds). There's really no fix for gear whine, so I just imagine I'm driving a rally car. I would suggest doing the same hehe :) |
#6 (permalink) | |
#8 (permalink) | |
Good luck bro! The bearings are probably just fine, the whining you hear is due to the gears meshing together. Ever heard a straight cut dogbox? Same sound.... It's completely a function of the gears meshing together. Due to the variation in each gear some people have the whine worse than others. Unfortunately, there is no way to fix it. It seems that Honda's transmission NV group was slacking on this car hehe ![]()
#12 (permalink) | |
Hehehe indeed a typical Honda "sporty car" trait! For some reason they seem to think jerky throttle response = sporty... lol
#14 (permalink) |
dido I have same issue with mine .I HAVE ANOTHER ONE ALSO iM HEARING AWIERD DEEP RATLE SOUND AT2800 62MPH ON HIGHWAY REALLY WIERD iM GONNA TAKE IT IN AND SEE WHAT THEYCOME UPWITH AS FOR VIBRATION THE MOTOR GETS OUT OF BALANCE AT 2400 RPM IN NUETRAL.ITS NORMAL.
#20 (permalink) |
TWFA5FTMFW
Resident Si Sedan Hater Hater
i was convinced my car was messed up until i read that many other people had the same noise.
and it's actually the engine i thought, cause it makes the noise out of gear. so would it be the tranny still? i thought it was anything from the hollowed balance shaft to the lsd to the tranny.....but whatever it is it gives me piece of mind to know you all are hearing the same thing....cause it is either supposed to be that way or a fix will be found. p.s. my girlfriend thinks i am crazy when i say "can you hear that"...i used to do it with my accord and now with my si and i can see her eyes rolling. |
| New 5-spd Auto Transmission Like/Dislike | GMech | Mechanical Problems & Technical Chat | 80 | 03-19-2008 08:46 AM |
| Transmission problem | ryryninja | Mechanical Problems & Technical Chat | 8 | 02-27-2007 02:37 AM |
| Honda Begins Production at Georgia Transmission Plant | webby | Honda Industry News | 2 | 05-19-2006 03:37 PM |
| Engine Whine. | Hondalways | Civic Coupe And Sedan | 25 | 05-18-2006 09:42 PM |
| Found out today my transmission is probably going to be replaced. | enter801 | Mechanical Problems & Technical Chat | 25 | 04-04-2006 09:49 AM |
