#62 (permalink) |
Nice thread OP.
I taught myself stick about two and half years ago and since that time I'd like to think that I've gotten pretty good at it. I can rev-match, double-clutch, and heel-toe smoothly and dependably without a second thought. Even so, I've still got a few questions about manual transmissions I'm hoping someone can answer.
Thanks. |
#64 (permalink) |
06civic:
The short version's like this... 1. Clutch peddle in. 2. Rev to the speed that the lower gear will have to be at to maintain the same speed as you are traveling (rev-matching.) 3. Physically down shift. 4. Let out the clutch peddle. 5. Engine brake or accelerate So long as you rev-match to the right RPM as you let out the clutch peddle, the shift should be smooth. |
#66 (permalink) | |
Glowaholic
So I was cruising along on a country road in 4th, no traffic, straight road so I was able to focus more on the task at hand. I made note of the RPMs while in gear as that would be close to the 'target' RPMs for what I was about to try. I put the car in neutral and was still coasting along not losing much speed at all, and I let the RPMs drop all the way (foot was off the clutch too). I slowly began giving it gas while GENTLY pulling the stick to 4th gear (not pressing clutch). The stick wouldn't move when the RPMs weren't near the aforementioned 'target', and there was no grinding or anything, but as soon as the RPMs were at the right speed to match the engine, the stick moved effortlessly into 4th. I can't imagine a practical use for this, and the chance of being off with your RPMs is pretty easy, in which case you'll grind, and we all hate that feeling. It's fun to try out, I thought it felt kinda cool, but otherwise use your clutch, it's not just there for looks! |
#67 (permalink) |
I just thought I would chime in real quik about the OP, our transmissions DO NOT have DOG engagement or dog gears. Dog gearing or straight cut gears are for sequential transmissions only! Our gears are helical cut or angled gears. The engagement is completely different from the way the teeth run together to the actual physical shift. If our transmissions had straight cut gearing the tranny would whine very very loudly and would be almost annoying. The upside to DOG engaugement is you get much stronger shifts, more controlled up and down shifting and the transmissions themselves are designed for much higher power applications. Great write up though, very informative and concise.
#68 (permalink) | |
#70 (permalink) | |
#71 (permalink) | |
#72 (permalink) | |
Glowaholic
#73 (permalink) | |
i know i may sound like total newb but..in the following quote, what does "off the clutch" (used in this context) mean?
#74 (permalink) | |
I was under the impression that since our cars have syncros we don't need to double clutch to downshift. Double clutching could save syncro wear, but I usually don't do it. I do rev match all the time though (espiecially when I'm doing heel-toe thru turns).... |
#75 (permalink) | |
Even if you disagree with the purported benefits of double clutching, there's no denying it sounds cool to boot. |
#79 (permalink) | |
I personally don't do it, but if from someone's explanation on another thread.. if you do it while the tranny is not under load (best time is when u're pushing gas and just let it off). There's a split window play period where you can pull into neutral and it'll be ok... saves a bit of clutch wear. So short answer to your question is No, but it can if you do it incorrectly. If you feel resistance when you're trying to go into neutral, don't do it. Be safe, use the clutch if you're not sure |
#80 (permalink) | |||
Sorry, havn't been on in a while.
.Quote:
Oh, and bump ![]() |
