Old 04-27-2007, 03:56 PM   #1 (permalink)
Asian Hamster's Avatar
David
Torque for wheels?
What is the torque necessary for the wheels? We're taking one off to change the tranny fluid and I need to know the specs for it. Also, is it right or left wheel for changing tranny fluid? Thanks.
Asian Hamster is offline
Old 04-27-2007, 04:02 PM   #2 (permalink)
reaper702's Avatar
80 ft/lbs
reaper702 is offline
Old 04-27-2007, 04:02 PM   #3 (permalink)
Tang Na!
darna's Avatar
christian
80 ft/lbs.
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline
Old 04-27-2007, 04:04 PM   #4 (permalink)
David
thanks, and which wheel for easy access to the filler and drain bolts?
Old 04-27-2007, 04:42 PM   #5 (permalink)
racerex's Avatar
Drivers side. Remember, you need to have the car dead level when you fill. If you're not level....and you're 100% postive that you got all the old MTF out.....make sure you get just under 2 quarts of MTF in.
racerex is offline
Old 04-27-2007, 05:23 PM   #6 (permalink)
David
Alright thanks, I'll do that. And just one more really quick question. Do the filler and drain plugs have a torque rating or do I just tighten them until they won't turn anymore?
Old 04-27-2007, 05:31 PM   #7 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Service Manual information for Si model...
Transmission drain plug, 29.0, 14mm
Transmission fill plug, 33.0, 20mm
Yodums is offline
Old 04-27-2007, 05:34 PM   #8 (permalink)
David
Thank you Yodums. You're literally always there for me. I think I love you.
+1 rep
Old 04-27-2007, 05:35 PM   #9 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
I hope you're a girl! Because I only swing that way. No problem man. :)
Yodums is offline
Old 04-27-2007, 05:46 PM   #10 (permalink)
Tom1222's Avatar
Tom Smith
I didn't take off my wheel for the tranny fluid change. Just jacked it up and it went fine. But it's the drivers side if you want to remove the wheel and the wheelwell covers.
Tom1222 is offline
Old 04-27-2007, 05:49 PM   #11 (permalink)
Scrodums
Yodums's Avatar
Hiro Nakamura
Similarly to what Tom mentioned, I didn't think it was necessary to remove the wheel or wheel well. It may make the job easier though. Sliding underneath the car constantly to refill the pump is really tiring! I think if you remove the wheel and wheel well, you can sit up right and do the job.
Yodums is offline
Old 04-27-2007, 07:02 PM   #12 (permalink)
BLU BY U's Avatar
83.200546 lb/ft anything more or less than that and you will lose hp.
BLU BY U is offline
Old 04-27-2007, 09:19 PM   #13 (permalink)
Tom1222's Avatar
Tom Smith
That explains why my wheels haven't been turning as fast as they possibly could I will retorque them first thing in the morning
Tom1222 is offline
Nissan SE-R Spec V Smokes Civic Si junsu Civic SI 193 06-28-2007 02:22 AM
Lug Nut Torque Values for the Si pennRON Civic SI 15 11-07-2006 01:44 PM
Maximum Torque Nox Forced Induction And Nitrous 4 09-07-2006 03:21 PM
torque specs ??? BLU BY U Suspension and Brakes 4 07-15-2006 03:21 PM
Torque wrench 8thgenuser Mechanical Problems & Technical Chat 8 03-24-2006 07:40 AM
