Old 04-26-2007, 09:00 PM   #1 (permalink)
Ryd1ZZ's Avatar
Ryan
Progress rear sway making strange noise?
So I installed my progress rear sway the other day and am starting to notice a "thumping" noise . I cannot really determine what causes it to make noise but it is kinda bothering me. Has anyone else had any issues with their sway bars? any advice on troubleshooting this would be greatly appriciated.
btw, it seems to happen when the car gets a little off kilter(if thats how its spelled) like when I pull diagonal into my driveway or up into a shopping center. It has also happend during aggressive turns
Ryd1ZZ is offline   Reply With Quote
Old 04-26-2007, 09:05 PM   #2 (permalink)
CAN I HAZ BBQ PLZ?
OMGWTFBBQIMDEREK's Avatar
Derek
did you check to make sure all the nuts nd bolts were tightened.. did you check to make sure you installed it the right way? aka not upside down where it rubs against stuff? uhm.. i dunno lol..
OMGWTFBBQIMDEREK is offline   Reply With Quote
Old 04-26-2007, 09:05 PM   #3 (permalink)
caveman74's Avatar
Kevin
Are you sure it is not upside down. Some have done that..
caveman74 is offline   Reply With Quote
Old 04-26-2007, 09:09 PM   #4 (permalink)
Ryd1ZZ's Avatar
Ryan
Will it fit in there upside down? My friend that works at FORD installed it for me and I am almost positive it is the right way. I called him 2day and he said he can put it back on the lift monday but I wanted to see if anyone else has had this issue or just input from my fellow 8th civic owners.
Old 04-26-2007, 09:13 PM   #5 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
check and see if its almost or actually touching the exhaust pipe. if it is its on wrong.
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Old 04-26-2007, 09:25 PM   #6 (permalink)
CAN I HAZ BBQ PLZ?
Derek
if its rubbing on your exhaust pipe thing.. then its definitely upside down.. and yes.. it IS possible to install it upside down.. i've seen at least 5 instances where people have done that.. if correctly installed.. it should NOT be touching anything.. there should be sufficient clearance from everything and the sway bar..
Old 04-26-2007, 09:25 PM   #7 (permalink)
CAN I HAZ BBQ PLZ?
Derek
you lose. really trust a guy who works on FORDS to install stuff for your HONDA??
Old 04-26-2007, 09:27 PM   #8 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
is there an echo in here.....
:failmyharryballs:
Old 04-26-2007, 09:36 PM   #9 (permalink)
CAN I HAZ BBQ PLZ?
Derek
i hate you.
Si Rear Sway Bar on CSX iluvmycsx Suspension 23 11-13-2008 09:13 AM
Anyone using the 30mm Front Progress Sway Bar? brthorner Suspension and Brakes 35 05-11-2007 10:22 PM
Progress Sway Bar johnai3 Suspension and Brakes 2 05-22-2006 01:08 PM
