Old 04-26-2007, 12:37 AM   #1 (permalink)
reaper702's Avatar
Thumbs down Major Tranny Problem !!!
well i just got back from the track and my ******* tranny went out! i was staging and everything was good, i had my rpms at ~3000-3500 and the light turned green so i dump the clutch, but not too fast and all of a sudden my car stops and it ******* pops out of first! i was like WTF so i push the clutch in and decide to shift to second a bit early and it didn't want to go in. so i finally got it in on my second attempt and i start speeding up, shift when it blinked, then to 4th without a problem. i get back to get in line to race and i notice my shifter feels really funny. then i test each gear and for some reason my gears are out of place and ******! i lifted the hood and it smelt like burnt clutch so i try shifting my gears with the car off and the clutch in and some gears it doesn't want to go in. then my 5th, 6th and reverse somehow moved further left and there is too much play in neutral. any ideas on WTF could be the problem?
reaper702 is offline   Reply With Quote
Old 04-26-2007, 12:39 AM   #2 (permalink)
whitecivicsi's Avatar
Damn that sucks bro...GL fixing it
I don't want to say it but I think the clutch/transmission is ******!
whitecivicsi is offline   Reply With Quote
Old 04-26-2007, 12:40 AM   #3 (permalink)
Mattzilla's Avatar
Matt
Maybe you broke a motor mount?
Mattzilla is offline   Reply With Quote
Old 04-26-2007, 12:41 AM   #4 (permalink)
Take it to the dealer if you're still under warranty. Just don't tell them you were at the track when this happened.
taffysi is online now   Reply With Quote
Old 04-26-2007, 12:44 AM   #5 (permalink)
reaper702's Avatar
indeed i am but they are closed til the morning just was wondering if anyone knew what it could be. i'm so ****** pissed off and they better not give me shit about aftermarket bs either.
Old 04-26-2007, 12:45 AM   #6 (permalink)
reaper702's Avatar
oh and i did not mishift the ****** gear popped out by itself! and i'm not sure a motor mount would cause the gears to be all displaced, right?
Old 04-26-2007, 12:53 AM   #7 (permalink)
reaper702's Avatar
anyone else got some suggestions? i'm depressed man...
Old 04-26-2007, 12:59 AM   #8 (permalink)
BATANG CITY JAIL's Avatar
have you look at the cable lines??? if something happen to your tranny, your not gonna make the car run, gears will be ****** so as the syncros....
oh well good luck and make sure you take the SS and the bushings out b4 you let them check it... or dont ever mention that you put them in there..
keep us updated on whats up..
Old 04-26-2007, 01:00 AM   #9 (permalink)
reaper702's Avatar
you think they will give me problems with my SS?
Old 04-26-2007, 01:05 AM   #10 (permalink)
if they found out that its an aftermarket, they can use it to avoid the warranty claim....... but just to make sure, take it out...
Old 04-26-2007, 01:06 AM   #11 (permalink)
280whp, 219tq, GReddy FTW
GalaxyGreySi's Avatar
Phil
you might wanna check the short shifter just to make sure nothing is out of the ordinary about it... I doubt they would give you any trouble just because of the short shifter though. *worst case scenario* = "sir, we checked out your car, and your short shift kit had come loose. We re-attached it properly. The diagnosis charge will be $86" You're probably not going to hear them say "sorry sir, but your transmission is F*cked UP!!! And guess what? It's not gonna be covered under warranty, because you're obviously abusing it, judging from that Short Shift kit you've got! HAAAHAHAHAHAAA!!!"
If you must whine about my Avatar, do it in this thread:
http://www.8thcivic.com/forums/showthread.php?t=35167
GalaxyGreySi is offline   Reply With Quote
Old 04-26-2007, 01:07 AM   #12 (permalink)
Phil
But yeah, take it out like Batang said. To be safe.
Old 04-26-2007, 01:16 AM   #13 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Your ss is probably loose...
Old 04-26-2007, 01:31 AM   #14 (permalink)
reaper702's Avatar
well i will double check tomorrow morning before i take it, thanks for your help...
Old 04-26-2007, 03:01 AM   #15 (permalink)
strCIVIC's Avatar
i don't think the dealer would correct your mistake.. it's gonna be a bitch fixing that whatever caused that if the dealer won't cover it.. but good luck bro!
strCIVIC is offline   Reply With Quote
Old 04-26-2007, 08:10 AM   #16 (permalink)
night shift whore
pineapple's Avatar
simply hawaiian
keep us posted.. i want to hear the turn out
pineapple is offline   Reply With Quote
Old 04-26-2007, 08:15 AM   #17 (permalink)
Vince's Avatar
Stephen "Vince" Carter
I don't have any idea why anyone would think that they can take a car to the track, beat on it racing, break it, and then think that Honda would take care of them on the warranty.
You've got to be high. But then so many dealers are equally as dumb, so you might just get it replaced!
*no offense intended
Vince is offline   Reply With Quote
Old 04-26-2007, 08:59 AM   #18 (permalink)
tennisfan16's Avatar
yeah i would check the ss just to make sure, when i installed mine i didnt put it on tight enough and I could barley shift into 1,3, and fifth gear. I could not shift into 2,4,6 at all.
tennisfan16 is offline   Reply With Quote
Old 04-26-2007, 11:13 AM   #19 (permalink)
reaper702's Avatar
no it isn't my SS and i did take it off just incase (PITA) and i'm taking right now.
Old 04-26-2007, 02:00 PM   #20 (permalink)
dario's Avatar
good luck man keep us updated
dario is offline   Reply With Quote
"Clutch" Squeak problem found.. Lobos8403 Mechanical Problems & Technical Chat 37 01-14-2008 09:51 PM
Window Problem waross Mechanical Problems & Technical Chat 14 12-17-2007 04:27 PM
Problem w/ Tein and Large wheels Max2.0 Mechanical Problems & Technical Chat 19 04-27-2007 07:15 PM
RE: Galaxycivic Amp problem damon300s I.C.E., Electrical, Security, & Navigation 2 12-26-2006 10:48 PM
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-12-2006 11:24 PM
