#1 (permalink)
Phantom Poster
![]() Join Date: May 2006
Justin aka Mr. JT
Fog Light Install
Anybody have directions on how to install ACI foglight kit....
They are the ESUSE ones JDM yellow.... My real question is on the OEM install you have the Blue wire that plugs into the back of the connector and the white with red tracer that goes in next to it... On the ACI ones you have only the White with red tracer.....why? |
Soup-R-Charged!
Ok, let me see if this is the same as mine was. If it is you have:
One relay that plugs into a little fuse box that goes no-where. Two blue 6 pin connectors, one male, one female. The lone wire, cant remember the colors. One ground. And a 2 pin connector. I think thats all the connections. Let me know what of those you have and if you have anymore, I'll help you out. |
#3 (permalink) | |
Phantom Poster
Justin aka Mr. JT
![]() Look at the connector on the OEM blue wire and white wire with red tracer why is there two on oem and one on after market? |
#5 (permalink) | |
Phantom Poster
Justin aka Mr. JT
Phantom Poster
Justin aka Mr. JT
![]() This one right....... they say some times in use and somtimes not in use.....if it is use the piggy back to T the two (female side is what factory side pluggs into...) |
#16 (permalink) | |
Phantom Poster
Justin aka Mr. JT
#17 (permalink) |
Phantom Poster
Justin aka Mr. JT
Oh the other thing...... no wires have to be run through firewall correct?
The brown connector with blue wire and red tracer is taped up behind the washer bottle correct? |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/37387-fog-light-install.html
| DIY: Install guide for OEM fogs... - Page 7 - 8th Generation Honda Civic Forum | This thread | Refback | 12-15-2007 03:23 PM | |
| K2 Fog light install...is it as easy as OEM?? | REv2Red | Lighting, H.I.D.'s, & Neon | 16 | 10-08-2008 08:44 PM |
| Fog light switch install for my 07 Si | TRY2HNG | Lighting, H.I.D.'s, & Neon | 0 | 03-25-2007 11:17 PM |
| Fog Light Install Help! | BlackCivic | California North | 1 | 03-17-2007 05:56 PM |
| 2007 Fog Light Install | slowmo9494 | Civic SI | 10 | 11-16-2006 10:55 AM |
| fog light install?? | taejinah | Lighting, H.I.D.'s, & Neon | 1 | 05-20-2006 08:57 PM |
