#24 (permalink) |
Phantom Poster
![]() Join Date: May 2006
Justin aka Mr. JT
the other thing...... no wires have to be run through firewall correct?
The brown connector with blue wire and red tracer is taped up behind the washer bottle correct? |
#29 (permalink) | |
Phantom Poster
Justin aka Mr. JT
Last question.... Did you take off your front bumper or do it from underneath? |
#31 (permalink) | |
Phantom Poster
Justin aka Mr. JT
thanx for the help...... |
#33 (permalink) | |
![]() vote for your favourite November picture here and/or post your own December Picture here
#35 (permalink) | |
Phantom Poster
Justin aka Mr. JT
#36 (permalink) |
\\ you mean.. run a wire from that red/white one so u can extend it into the other slot? hm.. never thought of it that way.. but let me know if it works// id like to do that heheh
I just finished installing my fogs (with the help of dentrecords on the wiring yday).. man what a fun install! lol show us pics when ur done n good luck! play safe :)
#37 (permalink) | |
Phantom Poster
Justin aka Mr. JT
#39 (permalink) | |
Phantom Poster
Justin aka Mr. JT
it's pre wired it's behind the washer bottle. You will see a brown connector look in my pix and you will see. here is the link... http://www.8thcivic.com/forums/showt...797#post746797 |
#40 (permalink) |
I got the same kit as shown by Imthevoiceofgod, and everything is connected EXCEPT the end of the wire, which said it should have a cap but if not to connect to the relay box (same as OEM). So i dont think mine came with a cap and when i goto connect it to the relay box, i dont see anything to connect it to. The fogs arent turning on and im assuming its because the "cap" end isnt connected. Any help would be appreciated.
EDIT: PROBLEM SOLVED !!! Last edited by Menez; 08-12-2007 at 07:06 PM. |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/37387-fog-light-install.html
| DIY: Install guide for OEM fogs... - Page 7 - 8th Generation Honda Civic Forum | This thread | Refback | 12-15-2007 03:23 PM | |
| K2 Fog light install...is it as easy as OEM?? | REv2Red | Lighting, H.I.D.'s, & Neon | 16 | 10-08-2008 08:44 PM |
| Fog light switch install for my 07 Si | TRY2HNG | Lighting, H.I.D.'s, & Neon | 0 | 03-25-2007 11:17 PM |
| Fog Light Install Help! | BlackCivic | California North | 1 | 03-17-2007 05:56 PM |
| 2007 Fog Light Install | slowmo9494 | |||
