Problem w/ Tein and Large wheels
I've got a problem
Tein Basics with a 17x8 +48 on 225/45/17 I can't drop in the front cause i'll get rubbing issues...even with a 3mm spacer I have 1" of gap in the front, this is the lower I can go or else tire is rubbing on the coil... no problem with oem suspension did someone get the same problem ? |
M.U.R.D.E.R
![]() Join Date: Mar 2006
Why did you get such a shitty offset? You have 16mm less clearance on the inside, and 10mm on the outside.
You should have bought wheels with an offset between +35 and +40.
![]() » Supercharged 2006 Honda Civic Si Coupe » Information/Teaser Video | ROTM | Carbon8mag Feature! » HondaArmy.com |
#5 (permalink) | |
8thcivic Sponsor
Jonathan www.z1auto.com 631-863-3820 Check out our BLOG for: http://cornerbalance.wordpress.com/ |
#6 (permalink) | |
M.U.R.D.E.R
#8 (permalink) | |
M.U.R.D.E.R
So it's 38mm wider than stock. You are going to need a 10-15mm spacer, and you're not going to be able to drop it all the way without some serious rubbing. Why did you get 8.5"?
#9 (permalink) | |
Only size avaliable, got it from Z1, they didn't have issues on theirs and it looks fairly low. |
#11 (permalink) | |
M.U.R.D.E.R
#14 (permalink) |
COMplex is right, you guys should have done a little research before you bought or at least done some measurements.
Anyway, to the OP: Max2.0 - If you are set on the wheels you have then keep them. Ditch those silly 3mm spacers and buy some real ones. Either get yourself some extended studs and buy some sandwich spacers @ 10mm WITH hubcentric rings OR you can also buy some 15mm bolt on spacers. I haven't seen anything less than 15mm for bolt on, that way your effective offset would be +33. With an 8" wheel and a decent street alignment you will not only look good/aggressive but won't have any rubbing issues. |
#15 (permalink) |
problem is partly solved
I bought 215 tires and I can drop it a bit more (not all the way down) I was running 2x3mm spacers with the 225 and wasn't able to drop more than halfway the basics can. Now with 215 and 1x3mm spacer I can go to 3/4 the basics can go (enough for me) I could go all the way down but i'll only have 1/16 between coil and tire... |
#16 (permalink) |
as for the research I did all lot of...
But guys were running oem struts... I also tried with oem struts ands there is absolutely no problems... no spacers, no nothing, 225 tires I thought Basics would be exactly the same.... Never assume cause you make an ass of you and me ! |
#17 (permalink) | |
#19 (permalink) | |
