Old 04-18-2007, 02:21 PM   #1 (permalink)
car salesman beware
Freq18hz's Avatar
Exclamation Injen CAI problem
I got an Injen CAI installed on my sedan a couple days ago, and I'm having a couple issues with it:
I notice that at low rpms, the car seems to buck if I lightly press the gas/let off. Also, around 2500 RPMS, I notice that if I have the throttle down about half way, the car seems to hesitate and then bogs down. At wide open throttle, the car seems ok, but I definitely don't feel a speed increase. Overall the revs seem to want to drop quicker, and the car feels like it is running really bad gas/has a touchy throttle response etc.
Has anyone noticed these throttle issues? Can someone give advice? Thanks,
-Freq
Freq18hz is offline   Reply With Quote
Old 04-18-2007, 02:22 PM   #2 (permalink)
honda06si's Avatar
justin
i would say....disconnect the computer and let it reset itself
or change your spark plugs
Old 04-18-2007, 02:23 PM   #3 (permalink)
NIGHTHAWKSI's Avatar
Ian
the "bucking" is a problem with all SI's. it has somthing to do with the DBW system and is yet to be completely fixed...as long as you are refering to first gear....
everything else sounds mostly like normal intake characteristics.
NIGHTHAWKSI is online now   Reply With Quote
Old 04-18-2007, 02:43 PM   #4 (permalink)
car salesman beware
Freq18hz's Avatar
nope not 1st gear...2nd and 3rd also. Pretty much anything under/around 2500 rpm or lower
-Freq
Old 04-20-2007, 06:04 AM   #5 (permalink)
kkim388's Avatar
Have you tried resetting the ECU as suggested? Also, look for hoses that might have been dislodged or not connected when the intake was installed.
kkim388 is offline   Reply With Quote
Old 04-20-2007, 11:13 AM   #6 (permalink)
bhoy's Avatar
Marv
i have an ex and i have the same problem. i unhooked the battery checked the plugs and still the same problem. i've learned to live with it and adjust my driving around it.
bhoy is offline   Reply With Quote
Old 04-20-2007, 11:20 AM   #7 (permalink)
SIis4ME's Avatar
ROMULUS
Check the MAF sensor, it could be bad or you installed it incorrectly. it is somewhat sensitive and when you removed it to put it on the CAI you may have damaged it.
Good Luck
SIis4ME is offline   Reply With Quote
Old 04-30-2007, 03:11 AM   #8 (permalink)
if u are having the problem still call group5motorsports in san diego...they said it has to do with the maf sensor position/orientation... good luck
slowpoke619 is offline   Reply With Quote
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 92 11-11-2008 08:57 PM
Injen CAI vs AEM CAI Review....hesitation etc. sickyute Bolt-Ons And All-Motor 118 10-07-2007 09:40 AM
injen cai start problem? erebusmetal Bolt-Ons And All-Motor 7 12-26-2006 01:04 PM
Injen CAI comments and review mtbiker278 Bolt-Ons And All-Motor 5 09-02-2006 09:35 PM
Which one first: Injen CAI or oem fogs?? reaper702 Bolt-Ons And All-Motor 22 09-02-2006 04:15 PM
