Be Aware! Tire Pressure..,
Hi all,
I just want to warn you guys about how stupid some of the dealers are( Isn't that obvious !). I bought my second civic (LX) 3 months ago, and I was getting a really rough ride. I could feel even the smallest bumps. The car was kind of jumpy in the highway. Yesterday, I checked my tires pressure and it was at 40 !!! I can't believe how stupid a dealer can be to set the tire pressure for a Civic to 40 psi! I took the car to another dealer and they reset the pressure for me (I do not do it myself because I do not trust these 4$ gauges). He told me when they receive these cars from the factory the tire pressure is set at more than 40, and they have to reduce the pressure. That means that the dealer from which I bought the car did not do it. So, if you feel your car is not as smooth as it should be, remember that tire pressures can be high, even if you just picked up your car from dealer parking. Amir |
The problem is that I have two different Gauges. Before taking my car to the dealer, one of them read the pressure as 40 and the other one 35. So, I realized that I can't trust my gauges. I think now I now that my first gauge is accurate.
One more thing that I forgot to mention is that I live in Michigan, and weather is crazy cold. I bought the car in January which the coldest time(Average -10 F) of the year. If the pressure in winter was 40, I think in summer it would be around 43 - 44. This again shows HOW STUPID DEALERS ARE! Amir |
Was your LX brand new when you picked it up? Normally tire pressures are intentionally set very high for shipping/transporting vehicles. The dealer would then lower the pressure to the recommended pressue as part of their inspection checklist when accepting the car or at least before a buyer picks it up. Sounds like this was missed with your car. I personally tend to like a slightly higher tire pressure to add a bit of stiffness for cornering purposes. But I'm driving an Si too. Always a good idea to check your pressures fairly often anyway.
8thcivic Sponsor
Mine was the same way when I took delivery at the dealer - 40psi!
Jonathan www.z1auto.com 631-863-3820 Check out our BLOG for: http://cornerbalance.wordpress.com/ |
#9 (permalink) | |
WooooHooooo
when you check your tire pressure, was it cold or running pressure? 40psi on running pressure = normal 32psi on running pressure = under inflated be aware that you are adding up somewhere between 5-8psi to your tire pressure when they are warm and running. the correct way to set tire pressure is when its cold, try early in the morning. i can go on and on but i'm sure u get the idea. if not then read this: Tire pressure check method??
![]() The last time I was inside a woman was when I went to the Statue of Liberty ![]() |
#10 (permalink) | |
This is a pretty concrete thing, the whole cold pressure, running/warm pressure.... |
#11 (permalink) | |
Amir |
| Boosting an FG FAQ | Highrev1 | Forced Induction And Nitrous | 53 | 10-07-2008 02:45 PM |
| Tire pressure check method?? | MADDOGSI | Mechanical Problems & Technical Chat | 19 | 02-19-2007 03:14 AM |
| Regarding tire pressure... | Goose | Civic Coupe And Sedan | 11 | 02-17-2007 04:24 PM |
| Recommended Tire Pressure on Proxes 4 | kicker_jace | Wheel And Tire Upgrades | 4 | 01-27-2007 05:30 PM |
| tire pressure query | RedCivic | Wheel And Tire Upgrades | 2 | 10-02-2006 03:33 PM |
