Old 04-16-2007, 10:25 PM   #1 (permalink)
Exclamation Motor mount bolt shifted?
I picked up an used 2006 4 drs EX about a month ago. It has 15000 miles when I bought it and have put on about 1000 since.
Today, while I was cleaning my engine bay I noticed an odd thing. I was able to snap few pictures to show you guys.
I think the left (if you looking directly to the engine bay) engine mount bolt moved, I could tell that it moved because you can kinda see the part where it was before (paint chip).
Do you think this is normal? Should I tighten the bolt? Anyone else ever experience this?
speedys4 is offline   Reply With Quote
Old 04-16-2007, 10:43 PM   #2 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
see if it's loose......I know there is a issue with motor mounts on the R18 engines.....it might have gotten the new one or it might have shifted...
it's either a 12mm or a 14mm bolt from the pix that I can see...
Originally Posted by ryker View Post
intial quality should be good when you spend 20K or more on a car. If I buy a 30.00 Polo shirt I damn well expect the buttons to stay put.
Originally Posted by fiji06si13 View Post
Well said..... now relay that message to honda......
RIP Bernie Mac
fiji06si13 is offline   Reply With Quote
Old 04-17-2007, 12:56 AM   #3 (permalink)
It doesn't look normal. I had one of my engine mounts replaced because it made a clunking noise. You should take it in just in case.
Old 04-17-2007, 01:04 AM   #4 (permalink)
volvo9's Avatar
Andrew
Give it a little twist with a socket and see if it moves. If it dosen't then it more than likely took a good hit to get that bolt to move, like a neutral drop or something. Hopefully someone dumb and young did not own that car before you.
Old 04-17-2007, 01:07 AM   #5 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
Just take it in to the stealership.
Ruthless909 is offline   Reply With Quote
Old 04-17-2007, 01:13 AM   #6 (permalink)
honda06si's Avatar
justin
x2
Old 04-17-2007, 08:54 AM   #7 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
+2 and let us know what it was...
RIP Bernie Mac
Old 04-17-2007, 10:00 AM   #8 (permalink)
Survivor's Avatar
Yeah take it in Now. I never had my mount out of the si yet but usually mount bolts will only drop straight in with NO play like what I see in the photo. Looks to be an elongated hole- but should it be? I hope not. Could be perhaps to sharing the same platform with a 1.8 and 2.0 ??? Dunno. Personally don't like it.
Just had another look at the pic. Looks like there should be a washer under the bolt head. This washer has a bent piece that acts to center the bolt in proper position which goes into the little hole right beside the bolt. I would go outside and look at mine but its pissin rain fierce now. Drive it easy to the dealership. Good luck.
I just attached photo
Attachment 5226
Survivor is offline   Reply With Quote
Old 04-17-2007, 10:41 AM   #9 (permalink)
Survivor's Avatar
Found a pic of an Si on this site--theres no washer. Found this under my hood! (Comptech) the F--- is that hole right beside it!!?? R our cars mising pieces. Now I want to go out and take mine apart to see if theres a washer sandwiched between the mount and body bracket. There must be somthing to maintaint the alignment- the tightening of the bolt is not suffencient enough. My 2 cents and then some.
Old 04-17-2007, 01:08 PM   #10 (permalink)
I bought the car from a family man, so I doubt that it's been abused or raced.
I end up trying to loosen the bolt, it doesn't take much to loosen it. After I loosen it, the bolt kinda went to the middle by itself. So I guess it was just loose from the factory??
It was 17mm bolt btw, anyone know how much you're suppose to torque this bad boy down?? Should I just tighten it as much as possible ... cheers
Old 04-17-2007, 02:33 PM   #11 (permalink)
honda06si's Avatar
justin
yea just tighten it as much as you can
Old 04-17-2007, 02:34 PM   #12 (permalink)
honda06si's Avatar
justin
the hole that the arrow is pointing to looks like it should have a lock bracket on it....you know like the front motor mount for the tranny to the subframe?
Old 04-17-2007, 02:43 PM   #13 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
I agree take it to dealer something is missing.....
RIP Bernie Mac
Seat belt bolt won't go back into my car! lostdaytomorrow Mechanical Problems & Technical Chat 9 05-20-2008 05:22 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 3 12-07-2006 02:59 AM
Requesting help in removing a bolt with stripped threads Junta Mechanical Problems & Technical Chat 14 08-17-2006 05:42 AM
Ground Bolt? dmm128 I.C.E., Electrical, Security, & Navigation 1 07-05-2006 01:24 AM
gear down shifted and rpm hanged at 3000. spunkin82 Mechanical Problems & Technical Chat 5 05-17-2006 02:49 PM
