Body panel misalignment - would you bother?
Do you guys think the dealer would make this situation worse? I'm not sure if the hinges would need to be adjusted or if the front fender is not installed correctly. I worry about scratched paint, damaged door hinge bolts, or something worse at the hands of a tech inexperienced in these kinds of problems.
As you can see, the driver's door has a distinct gap/misalignment. I've included a similar picture of the passenger side for comparison. ![]() ![]() To be honest, I noticed this at delivery and have debated with myself about getting it corrected. In hindsight, I should have simply not taken delivery of the car. Oh well... live and learn. Regardless of my decision on this issue, it's a sad commentary on Honda's current quality control. Thoughts? Last edited by Goose; 04-17-2007 at 08:29 AM. |
My thoughts are to ask the dealer. Thats the person who makes the decision anyways. I would DEFINATELY have gotten this checked out immediately.
I would get another dealer to use a paint gauge, my guess is that your 'new' car was repaired like others on this board.... |
#3 (permalink) | |
#12 (permalink) |
8thcivic Sponsor
If it bothers you have it fixed. Insist that the dealer sub-out to the body shop they use if they do not have one of their own.
I had the same issue on the reverse side - we took care of it in our shop. We have someone in house who does excellent paint/body work on our own cars.
Jonathan - www.z1auto.com - 631-863-3820 GT-SPEC FENDER BRACE PRE-ORDER! http://www.8thcivic.com/forums/z1-pe...-preorder.html Check out our BLOG for: -Customer rides -New products -Original articles http://cornerbalance.wordpress.com/ |
#13 (permalink) |
Don't feel bad
My hood doesn't line up correctly. It was like that when I took delivery as well. One side of the hood sticks up a little bit more than the other. I just adjusted the hood stoppers, (not sure what those are called), to make it look more even. I don't think it was damaged in transit, I just think honda has really skimped on the body work and paint on our cars.
If you look at most coupes, (I can't speak for sedans, I don't really pay too much attention to them), you'll see that things don't line up exactly right. Come to think of it. I think my car is similar to yours on the passenger side. It's not as noticeable, but the passenger side has a little bigger gap than the driver's side. |
#14 (permalink) |
If you're really picky get the paint thickness checked out, it was more than likely repaired after it left hondas hands, not really the factory's fault, if I back my car into a new dealer car and the fender needs to be replaced, they are not obligated to tell the customer.
#15 (permalink) |
Had this checked...
I checked with a body shop and they said it was factory paint. My dealer (who is near the body shop but not affiliated with it) took a look at the fender as well; they said that there's no way to adjust the fender. Considering that more harm than good may come out of trying to adjust such a small flaw, I'm not going to pursue this further.
Again, I admit that this situation really isn't a big deal and I should have noted it at delivery. Most folks wouldn't even care. I will say, though, that the quality of materials/assembly of this generation is lower than previous Civics. I realize that this observation is not a shock to most of you. After four Civics ('87, '93, '00, '07), this may be my last one. Thanks for your input on this one, guys.
| Cheap NEW Mod: IM to Throttle Body Thermal Heat Gasket | CorSport | CorSport | 117 | 06-13-2008 12:00 PM |
| Question About Body Kits | Kabs | Inside and Out | 7 | 01-20-2008 11:55 AM |
| Body work | redISblinking | Mechanical Problems & Technical Chat | 13 | 03-10-2007 11:04 AM |
| Body Repair | fijiblue06si | Garage | 2 | 07-05-2006 01:56 PM |
| Finally Sent Car to Body Shop | civicboy | Mechanical Problems & Technical Chat | 2 | 03-31-2006 04:34 PM |
