Trunk Lock broken
I guess my trunk lock was broken when i pulled the panel out to install the amp wiring. the lock will not engage, it just spins and doesnt lock anything. the dealer said it was my fault and they wouldnt fix it. understandable, however i looked at it again and it looks like two metal peices. does anyone know how to put this back together a certain way to make it work? i really cant see it just being "broke". thanks
Sounds like maybe the tension spring fell out. I had the same problem in mine. If you can find it, it's easy to put back, just pop off the black plastic covering and you can kinda see how it attaches back to the hook. If you can, take some pictures. And look for any small 1" long springs.
#6 (permalink) | |
Pretty much there's the black hook thing that keeps the trunk locked, and then the mechanism that moves back and forth, and a spring that allows the hook to snap into place. It, for the most part, just sits there and is why it's so prone to fall off. Mine fell off just by closing the trunk lid too hard. However you'll need like a flathead screwdriver to pry off the black plastic covering over the mechanism to see if the spring is missing. Then it's just a matter of attaching on side to the hook and the to the moving mechanism.
And, like before, if you can get some pictures of it with the cover off, and you are, in fact, missing the spring. I can show you exactly where it needs to go if you don't figure it out for yourselves. I'd take my own pictures but I don't have the Civic anymore. |
#8 (permalink) | |
Ahhh! Domokun!
![]() Join Date: Aug 2006
4dr WhOrE!!!
#11 (permalink) | |
Ahhh! Domokun!
4dr WhOrE!!!
#16 (permalink) | |
Ahhh! Domokun!
4dr WhOrE!!!
| 8thcivic Soap: Sad and depressing day for me | Blue Fox | Water Cooler | 1015 | 04-09-2007 02:42 PM |
