Louder than 4 F404-GE-400
Rolling Fenders
Any one got any advice on how to roll the lip on the fender to gain more clearance for the wheels. I got an Si with Tein SS and Tracklites 17x8 235/40/17. the front doesnt rub but the rear does even without the camber kit to straighten the wheels up.
here is the link, this is what most shop would use. But if want it cheap and some what ghetto another pic. This would work on any car.
http://www.bmwdiy.info/fender-rolling/index.html http://e46m3performance.com/installs...roll/index.htm |
#8 (permalink) | |
#9 (permalink) | |
Ahhh! Domokun!
![]() Join Date: Aug 2006
4dr WhOrE!!!
#11 (permalink) |
Me personally I would pay someone to do it using the proper equipment (ie. a tool designed specifically for rolling fenders) Not only will it most likely roll the fender more evenly but you risk cracking th paint if you don't know what your doing or you use a bat.
And by adding a camber kit to straighten the wheels up that would actually create more rub. Most people with wider wheels who might have rubbing issues use a camber kit to adjust there camber to a negative camber to lower the likelihood of rubbing. Aside from that stepping your tire size down to a 225 or 215 would really make the difference and i would go back up to an aspect ratio of 45 personally. Here is the comparison of different tire sizes stock compared to what you are running and how other sizes would compare. ![]() So I'd either recommend going with a 225/45/17 or back to the stock tire size of 215/45/17 both would give you more clearance. Yes they wouln't have as large of a contact patch but you give and you take. Wide tire=rub, slightly narrower tire= no rub. I know this is an old thread but I figured I would respond with the info I know. Last edited by dt07Si; 09-20-2007 at 11:08 PM. |
#12 (permalink) | |
try to go with a smaller tire like 225 or even a 215 if you dont want to roll the fenders. |
| Rolling shots | ILL FG2 | Introduction & Pictures | 89 | 03-31-2007 05:49 PM |
| Rolling Stones In Halifax | Whitey_14 | Movies & Music Reviews | 2 | 09-24-2006 12:20 PM |
| What do you think of Carbon Fiber Fenders | BLAZETIGER | Inside and Out | 38 | 08-14-2006 10:16 PM |
| black csx rolling on 17s | iluvmycsx | Introduction & Pictures | 2 | 06-04-2006 11:26 PM |
