Lost Oil during first 3k miles?
I was just about to change my oil for the first time at about 2900 miles. I checked the dipstick before starting. To my surprise it was about a 1/2 quart low. The car was on a level surface and had not been running yet that day. Called dealer service department.
Honda Service department told me not to change the oil until it reaches 15% oil life. He was very emphatic about not changing the oil yet. He said it is part of the break in period with the first oil. Is this correct? I've read some threads here from people who say they change their oil right away because they think it removes any loose metal shavings from initial break in. I would like to do a teflon treatment and use synthetic asap. |
08 HRP FA5
Don't put any Teflon in your engine!!!!
Even Dupont has an article floating around that states it's not for internal combustion engines. If you feel you need better, go syn. As far as burning 1/2 a quart in 3,000 miles.... I wouldn't worry. Lots of new cars burn a little oil during break in. It will go away with a few more thousand miles If it makes you feel any better, go and buy a quart of Mobil Clean 5000 or Exxon Superflo (both are rumored to be the same as the Honda Genuine oil) and fill her back up to the full mark. I would wait until you hit 15% to 20% before changing your factory fill. Some people will say that there is no such thing as break in oil . That's true for some cars, but Honda does use a beefed up OEM oil. I've seen the used oil analysis on the factory fills.Don't sweat it, it will all be OK. Good luck, Brian |
#10 (permalink) |
Keep in mind that you are supposed to check the oil on a warm car. You said your car had not been running that day, so the cold oil probably read a little lower than where the warm oil would run. I'm not sure if that would make a 1/2 quart difference, but it is something to remember. -Andy
#13 (permalink) | |
#15 (permalink) | |
For my first oil change, I took it out to 15% (around 6.5k), if I'm not mistaken. I added maybe a total of 1.5 quarts of dino oil over the first 6.5k miles. I switched to Mobil 1 at my first change and I'm using a 4k change interval. I currently have 12k on the clock and she is burning maybe a 1/4 quart between oil changes. |
| Oil Change DIY | ethlar | Engine | 239 | 10-14-2008 10:06 PM |
| THE OIL FAQ - synthetics, intervals, weights, brands | jdrumstik | Mechanical Problems & Technical Chat | 97 | 09-17-2008 03:45 PM |
| Everything Oil: All you'll ever wanna know | atruhondagrl | Bolt-Ons And All-Motor | 14 | 06-16-2008 12:45 PM |
| Oil Life | Elmacho | Civic SI | 28 | 04-25-2007 06:54 PM |
| 1 more month!!! | Ep3racer954 | Garage | 14 | 11-01-2005 09:53 PM |
