Code Scanners?
Howdy,
I recently bought a code scanner. Theoretically it supports OBD2 & CAN, which is what I thought the '06+ Civic was using... I can't get it to link with the car. Can anyone confirm what specs a code scanner needs to support for this car? Here's the scanner: http://www.harborfreight.com/cpi/cta...emnumber=94217 which appears to be a rebadged version of this one from Autel: http://www.auteltech.com/gs400.htm Anyone have any advice/input here? Thanks! Mark (50k+ miles on the 2006 civic now... Welcome to out of warranty! :-) |
I'm using a Snap-on MT2500 scanner with Global OBD2 software support. My asian/european software update is only about 6 months old. Thus I was unsuccessful trying to link it up to my 8th gen.
I ordered a CAN adapter from my Snap-on dealer and it's on its way. As of info from their technical support, OBD2 scanners won't on new vehicles like Mazda3, 5, 8th gen Civics... etc. I'll update if the CAN would work as expected. |
M.U.R.D.E.R
![]() Join Date: Mar 2006
For vehicles that are Model Year 2006 or newer, Honda has extended the new-car limited warranty powertrain coverage to 5 years/60,000 miles. It covers major engine and transmission components, except for standard maintenance items, body glass and interior.
Just to clarify that you're not yet out of warranty... But at the rate you're going, it won't be too long. If you're having problems, take it to a dealer. As for the scanner, I've only used the Honda HDS, so I don't know about a 3rd party scanner.
![]() » Supercharged 2006 Honda Civic Si Coupe » Information/Teaser Video | ROTM | Carbon8mag Feature! |
#10 (permalink) | |
#11 (permalink) | |
Howdy,
Turn the car's ignition to on, but don't start the car. Then turn on the scanner's power, and tell it to link. It doesn't link. Also tried it with that same procedure, except with the car running before trying to link. Still didn't work. Also tried a similar procedure with my '05 2500 Dodge Ram and the scanner didn't link there either (with the truck reporting "no bus" on the info display). I took that one back and tried another with exactly the same results. So at this point, I'm thinking the scanner isn't working or doesn't work with newer vehicles (despite supposedly being OBD II and CAN compliant, etc.) Anyone have any recommendations for a scanner that definitely works on the '06 Civic that displays test descriptions of the codes? It'd also be nice if it could check monitor status, any realtime display of operating parameters, etc. Cheaper is better, but I have to have at least the text description of the codes. It'd also be nice if it supported manufacturer specific codes from Honda, GM, and Dodge (what I currently own) and could be updated. Thanks! Mark |
#12 (permalink) |
Any OBD2 scanner should be able to read the codes as that is the reason they went to OBD2... to make them all able to read from the same interface. The OBD1 generations were pretty much manufacture specific.
Try taking the car to a Pep Boys or Checkers as I know they will read codes for free and see if they can get theirs to work on your car. If so, then the reader(s) you have is bad. I have an Equus INNOVA 3100 and it has worked fine on a variety of vehicles, but I have not tried it on my 8th gen yet. http://www.iequus.com/support/obd2_definitions.php |
| P0443 code, please help! | ominous8204 | Mechanical Problems & Technical Chat | 9 | 04-12-2007 01:29 AM |
| Where is the radio code??? | Johannes | I.C.E., Electrical, Security, & Navigation | 18 | 01-25-2007 01:11 PM |
| Cheat code to override transponder! | surf40 | I.C.E., Electrical, Security, & Navigation | 7 | 01-01-2007 11:29 AM |
| Anti-Theft code | SacrificeTheory | Civic Coupe And Sedan | 6 | 09-22-2006 05:36 PM |
| Heads-up...ALERT!!!! Protect your radio code | MyFirstCivic@35 | I.C.E., Electrical, Security, & Navigation | 6 | 04-16-2006 12:48 AM |
