#21 (permalink) |
Kill Your Self Krew
you can buy gm synchromesh friction modified from from any gm dealer. that stuff is great.
#23 (permalink) |
i have amsoil in my tranny and it completly fixed my 3rd gear problems
i still have the 2nd gear grind every time i shift into 2nd at WOT at redline today coming home i shifting into 2nd and it went it but not fully only about 85% this is buging the heck out of me should i take it to the dealer and try to get new gear/syncros? |
#25 (permalink) |
i went to the dealership about the 2nd and 3rd gear problem and they said its because of the cold weather in jersey and that the tranny is cold if it keeps up in the spring or summer im just going to change to amsoil thats definetely your best bet i will most likely change to that also
#26 (permalink) |
I noticed that after switching to Amsoil for my tranny 2nd gear started grinding at high RPMs.
Basically the only way I can avoid grinding 2nd at high RPMs (above 7500) is to shift slow. I'm sure it is just a case where I am not fully disengaging the clutch when I "speed shift". Just found it strange that it never happened with the old "crap" tranny fluid. Maybe it being overfilled from the factory helped cover any bad shifts. Then again I can shift as fast as I want any other gear/rpm so I don't see how I can just be screwing up my shifting into second. Maybe it's my short shifter, thinking about taking it out and trying some high speed 1 -> 2 runs. Last edited by tommyroo; 04-18-2007 at 04:26 PM. |
#27 (permalink) |
My best recommendation is to go with Amsoil. I did on mine and it's smooth. However, when it is cold <40 degrees, 1st to 2nd syncros don't line up quick enough and 1st pinches while 2nd does not let me in easily. The only solution is to slow your shifting in cold weather.
Oh yeah, and Honda dealerships suck. They will try to stick it to ya every time. |
#28 (permalink) | |
I am using Royal Purple Synchromax and so far no grinds of any kind |
#29 (permalink) |
Our cars have a fair shair of issues
. I met a guy today that had an 07 Si. His second was grinding badly. It was grinding while he was at a stand still... he put it into second at a stop just to show me how bad it is.Personally my tranny has yet to grind or pop out. I'm at 5000 miles. Third is very notchy though. Maybe i'm lucky because of all the VTEC i hit when the car only had 10 miles on it, lol |
| Why the rarity? | honda93 | Garage | 41 | 03-17-2008 06:08 PM |
| Recalls, TSB's, and Common problems with the 8thgen civic... | Jrfish007 | Mechanical Problems & Technical Chat | 153 | 12-13-2007 03:20 PM |
| New Honda MTF...FTW | Fg2ner | Mechanical Problems & Technical Chat | 5 | 04-06-2007 03:51 PM |
| My fuggin passenger seat broke. | amdhunter | Mechanical Problems & Technical Chat | 44 | 10-21-2006 11:20 AM |
| 2006 honda world news | webby | Garage | 0 | 07-25-2005 10:31 AM |
