1st gear problem
when im coming up to a stop light or stop sign i put the car in neutral and roll to a stop when i go i push the clutch in and put the car into first when i do this sometimes the gear will not lock in but the clutch is all the way down and its as if the clutch isnt being pressed at all what could this problem be caused by me or is this just a common thing because this is my first MT car cuz i dont want to spend money to fix something that doesnt need fixing
any help plez driving me crazy |
#4 (permalink) | |
![]() Join Date: May 2006
J. M. back by popular demand!
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
Just curious. Are you still rolling when you try to put it back into gear? I've had problems putting it into the lower gears while the car is moving. I'm not sure if it's some sort of 'speed lock' or what, but yea. Good luck. Keep us posted on what happens after ya bring it in! :)
#9 (permalink) | |
#11 (permalink) |
The dealer won't say anything. 1st gear has the most resistance period and is always the toughest gear to downshift into. Unless you are on a racetrack/auto-x course then downshifting to first is not really that necessary or useful. Lots of trannies do not have speedlocks on them and quite honestly I doubt this one does. Usually a speedlock is just the fact that you are going to fast and/or not rev-matching to downshift.
Still want to downshift into first? Things to try/consider: 1) rev match, rev match, rev match 2) as someone said, 1-2 gears are on the same slider, try shifting to 2nd gear first then going to 1st. If you are already downshifting through the gears properly, by the time you want to downshift to first you should be coming out of 2nd at the proper speed and there should be no problems 3) switch to a better MT fluid, ie: amsoil 4) rev match again 5) practive downshifting into first from slow speeds (under 10-15mph) first and get used to blimping the throttle to rev match. Then once you get better try it at speeds a little bit higher. 25mph 1st downshift should be no problem if you are doing it correctly. <-- to the OP BTW since he said its his first MT car Good luck! It sounds like everything is normal to me, you just need a little practice and all will get better! |
#12 (permalink) | |
#14 (permalink) |
i guess that its jus the gears not locking but other then that it does fine an i decided not to take it in an spend 100bucks for them to tell me that its fine but it might be the trannyfluid cuz it did come from the dealer but i dont know ill change it when i need to cuz i dont wanna change anything right now cuz im not even in the 1000 mile range im like in 600 miles besides im braking the car in so i think it should go away over time but if not ill definently take it in to get it looked at with out hesitation
| 1st gear question | kamikaze84 | Garage | 7 | 03-21-2007 12:08 AM |
| First gear problem now... | Omes | Mechanical Problems & Technical Chat | 1 | 03-07-2007 02:33 AM |
| 5 Speed Shift Problem, gear don't "pop" | Way2Short | Mechanical Problems & Technical Chat | 12 | 02-03-2007 07:37 PM |
| 07 Problems | todsulli | Mechanical Problems & Technical Chat | 33 | 01-29-2007 11:38 AM |
| 1st GEAR!!! | LiL Sang | Civic SI | 15 | 11-06-2006 01:34 PM |
