Old 04-11-2007, 10:57 AM   #1 (permalink)
Fuel smell from the vents on start-up
On my 2006 Sedan, with the vents set to fresh air, if I park my car for a few minutes and get back in and start it up I get a noticeable fuel odor that blows through the vents in the dash. It only lasts a couple seconds but it is noticeable and repeatable.
Keep in mind that the car is still hot when this occurs too.
Does anybody else notice this? Maybe give it a try.. keep the fan speed set to low, fresh air, ac off and when you start it (when its still hot) see if you get the gas smell...
jayjr98 is offline   Reply With Quote
Old 04-11-2007, 11:21 AM   #2 (permalink)
Sli(ks's Avatar
Mine (06 lx coupe) did the same thing lastnight, and I usually have my fan/a/c at the same settings.
Sli(ks is offline   Reply With Quote
Old 04-11-2007, 04:39 PM   #3 (permalink)
Well its good to know that I'm not the only one who notices this... It is minor, yet almost always noticeable.
The last thing I want to do is take it to the dealer to investigate a fuel leak... God knows all they will say is, "we don't smell anything -- we can't find anything -- everything is great"
Old 04-13-2007, 08:20 PM   #4 (permalink)
Jonas
This sometimes happens to me too. But my a/c wasnt on.. only the fans.. Is this an issue that i should be concerned of?
aiz121 is offline   Reply With Quote
Old 04-14-2007, 06:31 PM   #5 (permalink)
Hey, mine does that too. I had it at the dealer several times and they say, we dont smell anything, its the cars in front of you.
Yeah, the car in front of me in my driveway is a garage door !
anyway, anybody know why it does this ??: ohnoes:
labelman42 is offline   Reply With Quote
Old 04-14-2007, 06:59 PM   #6 (permalink)
turn that thing on where it only circulates the air from inside your car and not from the oustide
imtim25 is offline   Reply With Quote
Old 04-14-2007, 11:22 PM   #7 (permalink)
Never had this problem on my 06 LX sedan. I drive mostly with vent open, just about every day!
Old 04-16-2007, 02:21 PM   #8 (permalink)
I have 06 sedan to but notice this happens mostly on cold starts makes no difference if its -30 or a +30 cold start. I notice it since the first week i bought it... Only last a few seconds it has not gotten worse and never really concern me to. maybe i should bring it in.
Royal_T is offline   Reply With Quote
Old 04-16-2007, 02:39 PM   #9 (permalink)
+1
This will stop it everytime. It seems that Hondas/Acuras bring fuel smells inside if the outside air vent is on. I put it on recirculate and it goes away. Has happened with my Integra, 06 Civic and now my RSX.
If it's still noticable on recirculate then you might have a problem.
honda11 is offline   Reply With Quote
Old 04-17-2007, 12:09 PM   #10 (permalink)
NoRemorse's Avatar
Brian
My car always gives of obnoxious when I am not moving (not catalytic converter) so I just leave the vent's of my car on recirculate, so it does not draw air form the outside.
NoRemorse is offline   Reply With Quote
Old 04-23-2007, 01:29 PM   #11 (permalink)
Originally Posted by honda11
+1
Yes that will fix it but with fresh air on (which is all I ever use unless its extremely hot outside) there should NOT be any fuel odors. It's not the end of the world but it is annoying. My other Honda doesn't do this EVER.
Old 04-24-2007, 09:36 AM   #12 (permalink)
fuel odor?
Since the fuel system on all new vehicles is a closed loop there should never be a fuel odor coming from under the hood or through the vent system. The whole system is designed to eliminate raw fuel and if you smell fuel (gasoline) something is wrong. Exceptions...a car in front of you is leaking gasoline and that odor persists a while after it turns off...you just filled your gas can for your lawn mower and it is in the trunk or recently was in the trunk....you are at the gas station filling your tank (or gas can) and this smell invades the interior as you leave. Otherwise NO raw fuel smell should be there..
targettuning is offline   Reply With Quote
Old 01-03-2008, 03:03 PM   #13 (permalink)
Bump.....
Has anyone had this problem solved????
jd06lx is offline   Reply With Quote
Old 01-03-2008, 04:11 PM   #14 (permalink)
FlyJigga's Avatar
Yimmer
yeah my balls
FlyJigga is offline   Reply With Quote
Old 03-28-2008, 11:30 AM   #15 (permalink)
Originally Posted by FlyJigga View Post
yeah my balls
Please explain how your balls solved this problem.
Boosting an FG FAQ Highrev1 Forced Induction And Nitrous 53 10-07-2008 02:45 PM
Nitrous 101 FG*SQUAD Nick Forced Induction And Nitrous 22 05-26-2007 02:50 AM
possible ajp/turbo/supercharger issue? reflash? fuel? sickyute Forced Induction And Nitrous 55 02-21-2007 03:46 AM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
