Old 04-10-2007, 02:59 PM   #1 (permalink)
Engine dies at 3500 rpm, tach be a bouncin too
Newbie post!
History:
95 civic 1.6 vtec. SE coupe 268K miles
Car died at 3500 rpm, turned key back on, ran. Car died again the next time, no restart. Sat for 5 minutes, started up, died at 3500 rpm.
Changed:
ignition switch, coil, cap, rotor, plug wires, plugs, fuel filter.
White paper... VTEC not getting oil so it shuts off fuel, usually low oil level. I check, sure enough, low oil level. Fixed oil leak, check oil every day.
Ran okay, meaning it didn't die,except for the tach bounces a bit at around 3500rpm, and it has a stutter or I can't explain it at 3500rpm for about a week.
Now.
Car sometimes dies at 3500 rpm, turn off key, turn back on, runs.
Car sometimes repeats the dying issue, but tach always bounces at 3500rpm.
Oil level is fine. Tach still bouncy and car will usually die if I get over 3500 rpm with the same type of thing as before. I can cruise along all day with no bouncey tach, nor car dying, nor stuttering if I stay below 3500 rpm.
Could be oil pump not delivering at higher rpm.
Could be something electrical, although I dunno what.
Fuel pump is fairly new.
NO CHECK ENGINE LIGHT comes on either!!
So.. I am at a loss. Any help?
Thanks!
j-bo
ps.. i did a search and no luck
j-bo is offline   Reply With Quote
Old 04-10-2007, 03:02 PM   #2 (permalink)
honda06si's Avatar
justin
wow
umm
lets see.....
wrong forum?
try to post this same thread here
http://honda-tech.com/zeroforum/1
Old 04-10-2007, 03:10 PM   #3 (permalink)
Thanks!
I'll delete it.
Well. can't delete it. Thanks for the help.
2006 Honda Civic Engine Information webby Garage 6 11-21-2008 04:23 PM
2006 check engine light and dont go over 3500 rpm bodydraggin Mechanical Problems & Technical Chat 15 07-21-2008 09:48 PM
2006 Civic Engine: I-VTEC webby Garage 8 10-16-2007 12:54 AM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
