Old 04-09-2007, 07:36 PM   #1 (permalink)
USDM-FG2's Avatar
Dan S.
2500 RPM Shake!
Does anyone else notice it. Slowly rev passed 2500 RPMS, i feel the whole car shake a little.. anyone else?
USDM-FG2 is offline   Reply With Quote
Old 04-09-2007, 07:49 PM   #2 (permalink)
WooooHooooo
darna's Avatar
Ate Vi
mine does it on idle and when i go over 70mph... i bought hub centric rings to eliminate the vibration and it seems to work fine.
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline   Reply With Quote
Old 04-09-2007, 07:52 PM   #3 (permalink)
dukhunter20's Avatar
Brett Hutchens
I feel this usually when i'm warming the car up. I havn't noticed it while driving. I'm almost positive that this is normal.
dukhunter20 is offline   Reply With Quote
Old 04-09-2007, 07:54 PM   #4 (permalink)
VTEC!
Old 04-09-2007, 08:52 PM   #5 (permalink)
ReDHatchyGuy's Avatar
David
i've noticed it too... seems as though something in the motor is not balenced right...
ReDHatchyGuy is offline   Reply With Quote
Old 04-09-2007, 09:26 PM   #6 (permalink)
TJ213's Avatar
If I rev to 2500 it does this, but its fine while moving
Old 04-09-2007, 09:29 PM   #7 (permalink)
280whp, 219tq, GReddy FTW
GalaxyGreySi's Avatar
Phil
Yeah, mine does it too. More noticeable now that I have the lightweight flywheel in it too. Like twice as bad.... only in neutral tho. Not while moving.
GalaxyGreySi is offline   Reply With Quote
Old 04-10-2007, 02:12 PM   #8 (permalink)
USDM-FG2's Avatar
Dan S.
Thanks for the responses.
Old 04-15-2007, 03:28 AM   #9 (permalink)
nevarez_ga's Avatar
Yeah man, i felt it today in gear and neutral. BTW I forgot about it until i read the post.
nevarez_ga is offline   Reply With Quote
Old 04-15-2007, 05:01 PM   #10 (permalink)
RWatters's Avatar
I was asking another local person about this and they didn't have it. I thought I was the only one who had this trouble at 2500RPM!
I wonder if it's possibly a motor mount problem?
RWatters is offline   Reply With Quote
Old 04-15-2007, 05:19 PM   #11 (permalink)
nevarez_ga's Avatar
If a vibration or sound wave occurs (engine running) with the same frequency as the engine bay resonance frequency, it'll shake, and shake more than at any other RPM. So, since our problem happens only @2500 rpm, it indicates something else, otherwise it means all of the cars with this problem have EXACTLY the same mounting problem and not only that, but they all would shake at different RPM, not only 2500. That's the only thing I can think of
Old 04-15-2007, 05:27 PM   #12 (permalink)
nevarez_ga's Avatar
So I guess it could be two things 1) It's normal, 2) Something's bad inside the engine (hope not!!)
Old 04-15-2007, 05:30 PM   #13 (permalink)
articsilber323's Avatar
i have the same problem also
articsilber323 is offline   Reply With Quote
Old 04-15-2007, 06:23 PM   #14 (permalink)
TJ213's Avatar
maybe its some sort of resonance, whatever it is, it can't be that much of a problem if we all have it, if it was it would have been solved at the factory
Old 05-28-2007, 02:16 AM   #15 (permalink)
JaaronK's Avatar
Jesse
Yeah I have the problem as well.
"And God said let there be i-VTEC. And then there was a great earthquake... The seas boiled and the skies fell; All fell silent as the roar of 5,800 RPMS echoed across the Earth."
JaaronK is offline   Reply With Quote
Old 06-02-2007, 12:22 PM   #16 (permalink)
drm
I bought my Si three days ago, it was made last month (May '07). I have this shake too, about 2300 rpm. I was really freaked out, thought something was trashed in my motor (e.g., balance shaft off a tooth, or low compression in one cylinder). I guess it is "normal" since so many seem to have this problem. When I really feel/listen to it, I think it is most likely a fuel injection timing problem. I have a LOT of automotive/mechanic experience going way back, and this is where I would look first. If you listen to the exhaust carefully at this RPM, there is a bit of backfiring down the exhaust pipe.
drm is offline   Reply With Quote
Old 06-02-2007, 12:24 PM   #17 (permalink)
drm
also another thread here:
http://forums.clubsi.com/ubbthreads....at/topic/76727
Old 07-11-2007, 06:01 PM   #18 (permalink)
ABQSI's Avatar
Dustin
Me too
I have this too. It's most noticeable when the car isn't moving and I slowly increase engine RPM's. Seems to only be between 2200-2300 RPM. I won't worry about it unless it gets worse.
ABQSI is offline   Reply With Quote
2006 check engine light and dont go over 3500 rpm bodydraggin Mechanical Problems & Technical Chat 15 07-21-2008 09:48 PM
The first time 6k+ rpm powerbook76 Driving Experience 15 04-09-2007 08:53 AM
RPM &Temp Mateen Civic Coupe And Sedan 13 11-29-2006 07:53 PM
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 02:54 AM
Best Cruise RPM for fuel economy? NeverNZ Civic Coupe And Sedan 36 07-30-2006 01:19 PM
